Tyanks for the pics..Looks good. The AGM battery seems to work fine, but it looks like my charging system is hosed.
I get a red "charger" icon when I connect the charger, and will not charge. I probably screwed it up when I was trying to charge the car with the 12v bqttery dead. Connected an external battery charger to try to get it to charge, anD i think that caused some problem.
Tried the 30 second on, 4 hours off with all doors locked as recommended bY Kiwi, but still having trouble,.
The car indicates a problem with the el3ctrical system upon starting, but driveable. Regen braking works.
I will try the reset method again: disconnect batttery, reconnect, turn car on for 30 seconds, turn it off lock doors and wait 4 hours (actually I wll let is sit ovenite).
