Fast Eddie B
Let me clarify a few things that may have been misunderstood.
I installed an L14-30R receptacle, and an L14-30P plug onto my hangar door wiring, to enable me to plug my 240v hangar door into a 240v generator with the same L14-30R receptacle in the event of a power failure. As such, generator power is never being fed into the house wiring. This setup was conceived prior to thinking about using that 240v for charging the Clarity. As an aside, the hangar door needs no neutral, so none was run to it, and the neutral lug on the receptacle in unused. My working assumption is that even though it’s so labeled, it probably does not meet code. Generators may have a bonded neutral or a floating neutral, so that needs to be considered, though I don’t think it’s a factor here. Mike Sokol is the guru for such things: http://noshockzone.org/generator-ground-neutral-bonding/
Now, the thought is how to get this 240v into the stock charger. I assume the plug on the stock charger needs to be fed 2 120v “legs” to the blades normally used for 120v “hot” and neutral, plus a ground. As in my prior photo my adapter cable will have a male L14-30P on one end, and a female 15A socket on the other for the charger to plug into. Hence, no “suicide rig” that Kentucky Ken warned about.
Adapter cable fabricated:
Now I just have to work on building up my courage!
(I’ll add to this post in increments, so check back if interested.)
