MrFixit
Any ideas?
It is almost certain that your adapter is inadequate. Your screen shot doesn't really go far enough. We need to see what happens after the "22202a" command. There should be a LOT of data after that command (as shown in Post #32 above). You will NOT necessarily get a buffer overflow message... Not all of the bad adapters produce an error message, but they WILL terminate the data prematurely.
We have tried to emphasize the importance of a capable adapter... Buy the recommended $25 adapter and you will be OK.
Our experience has been that almost none of the "cheap" adapters are adequate
Got Car Scanner and noticed it has a profile for Clarity, so do we need to use these dashboards?
Regarding the Clarity profile in Car Scanner - We provided this profile to Car Scanner. It should yield the same results, BUT since we continue to work on this, the Car Scanner profile is not always current. The "Dashboards" really have nothing to do with the profile, you can set up whatever dashboards you like (whether you use the Clarity profile, or the Custom PID's provided here). We provided these dashboards to make it easier for people to get started. Delete them and make your own as you like.
