EV ownership is full of acronyms and terms that can discourage new or prospective owners from making the jump from ICE into an EV. This list will give you a leg up on learning about the cars, how they operate, and help define common phrases used on the forums.
EV Acronyms
1
1PD
- 1 Pedal Driving
- see also: One Pedal Driving
A
AC
- Alternating Current
ABC
- Always be Charging
ADAS
- Advanced Driver Assistance Systems
- Tech that warns the driver or corrects potential mistakes via use of radar, cameras, sensors, etc
- Emergency braking, lane keep assist, and adaptive cruise control are common examples
AV
- Autonomous Vehicle
AVAS
- Acoustic Vehicle Alerting System
B
Battery Chemistry
- Batteries are built from different elements such as lead-acid (Pb), Lithium Iron Phosphate (LiFePo4), Nickel Manganese Cobalt (NMC), Nickel Manganese Cobalt Aluminum (NMCA) among others and uses a chemical reaction between two electrodes (anode and cathode), separated by an electrolyte, to store and release energy as electricity
BEV
- Battery Electric Vehicle
Bi-Directional Charging
BMS
- Battery Management System
- Used to control charge and discharge to the battery to protect it and balance the cells
C
CCS
- Combined Charging System
- CCS Type 1 - more common in the North America and Japan
- CCS Type 2 - more common in Europe and Australia
- Offering a Mennekes Type 2 plug with 2 additional DC connection points to enable Level 3 fast DC charging
- Both CCS Type 1 and CCS Type 2 connectors are designed to be backwards compatible with their respective AC charging connectors.
- CCS Type 1 EVs can charge at both CCS Type 1 and J1772 stations
- CCS Type 2 EVs can charge at both CCS Type 2 and Mennekes Type 2 stations.
- EVs with only a J1772 or Type 2 connector cannot use the DC rapid capability of CCS1 or CCS2 stations, respectively.
CHAdeMO
- Level 3 charging port
- Bi-directional for V2G connectivity
Charger
- see EVSE
- Generally, the charger itself is part of the vehicle. The charging station merely offers a way to purchase the energy and a cord to supply it to your charger in your vehicle.
Charging Levels
- Level 1 - Generally 120 AC
- Standard home outlet, 5-10 miles per hour of charge (varies by model)
- 1.3-2.4 kW
- Level 2 - Generally 240 AC
- Most home EV charging systems provide this level, and offer about 30 miles of range per hour (varies by model)
- 3-20 kW
- Level 3 - DC, Voltage Varies
- 100-200 miles range per hour charge (varies by model and amp)
- 50-350 kW
CO2(e)
- Cardon dioxide equivalent
- sometimes refereed to as Grid Intensity
- The amount of greenhouse gases emitted (i.e grams of CO2 per kWh, or kg CO2 per MWh) utilizing electricity from the regional grid.
Control Pilot
- The Control Pilot (abbreviated as CP or EVCP) signal enables basic communication (sometimes called Basic Signaling, or BS) between the EVSE (charging unit) and EV (electric vehicle). This is a standard defined in IEC standard 61851-1
- This signal is a pulse width that sends information about max charge rates to the EV and signals like charge complete back to the EVSE.
- There are 6 main statuses:
- A - EV Disconnected - +12V signal
- B - EV Connected - +9V signal
- C - EV Charging - +6V signal
- D - EV Charge, Ventilation Required - +3V signal
- E - Error Condition - 0V signal
- F - Fault Condition - -12V signal
CPO
- Certified Pre-Owned
- A Dealer-sold used car that is inspected and given fresh updates such as tires and brakes and sometimes includes longer warranty periods
- Charge Point Operator
- A company that owns/maintains a charging station
- Several popular examples include:
- IONNA
- Electrify America
- EVgo
- Tesla Super Charger Network
- Chargepoint, Inc
CSMS
- Charging Station Management System
- A platform for managing charging stations
D
DC
- Direct Current
DCFC
- Direct Current Fast Charge
- See Also Level 3 charging
E
EV
- Electric Vehicle
EVSE
- Electric Vehicle Supply Equipment
- This is your charging equipment, cables, etc
F
FCEV
- Fuel Cell Electric Vehicle
- Generally powered by hydrogen fuel cells to produce electricity for the electric motor(s)
Friction Braking
- Normal braking process using pads/rotors in most cases to slow down the vehicle. The heat produced is not turned into energy in most cases but is needed to safely stop the vehicle when the regen braking system is not offering enough resistance to reduce to desired speed or stop.
Frunk
- A Trunk in the Front: FRont trUNK
G
GBT
- Sometimes written as GB/T
- Charger connection type mostly found in China and Eastern Europe
- Supports Level 1 -3 charging
GOM
- Guess-O-Meter
- Estimate of range left based on historic driving patterns and various sensor readings
H
HEV
- Hybrid Electric Vehicle
- A Vehicle that usually has a gasoline engine and an electric motor, but lacks plug-in charging and relies mostly on regenerative braking to charge a small battery bank (eg, the first gen Prius)
I
J
J1772
- Standard round plug for Level 1 and Level 2 charging
- Sometimes called the "J-Plug"
- Adding the DC ports enables it into the CCS Combo Type 1
J34002
- NACS plug type
K
kW
- Kilowatt - 1000 Watts
- 750 Watts = 1 HP
kWh
- Kilowatt-hour
- Energy consumption, as in supplied by the power company.
L
LiFePo4
- Lithium Iron Phosphate Battery type
- see also: Battery Chemistry
M
Mennekes Type 2
- Common European Charger connector type
- see CCS Type 2 for Fast Charge by adding the DC ports
MPGe
- Miles per Gallon Equivalent
- Used to measure efficiency in comparison to an ICE vehicle. 1 Gallon of gasoline is baselined as containing 33.7 kW of equivalent energy
N
NACS
- North America Charging Standard
- or, North American Charging System
- Level 3 charging port, Tesla proprietary but they have opened up the technology to other makes to leverage the port and network of chargers in recent years.
- J34002 standard
- Many major auto brands in the US are adopting this as the go-forward standard for North America charging stations.
NMC
- Nickel Manganese Cobalt Battery type
NMCA
- Nickel Manganese Cobalt Aluminum Battery type
O
OCPP
- Open Charge Point Protocol
- A charging universal protocol, or standard, language used to communicate between EV charging stations and management systems
One Pedal Driving
- Some EVs have a setting to allow the accelerator pedal control both acceleration and deceleration by engaging regenerative braking when the throttle is reduced, slowing the car down by simply reducing throttle input
- Sometimes abbreviated as 1PD
P
Pb
- Lead Acid Battery type
PHEV
- Plug-in Hybrid Electric Vehicle (eg, the Honda Clarity)
- Larger battery bank vehicles that can operate as pure electric with more electric range than HEV, but still rely on the ICE system to travel longer distances
Plug Type
- The style of connector from the charger to your vehicle.
- See: EV Plug Types: A Guide to Types of EV Charging Plugs & Uses
Proximity Pilot
- A safety feature in EV charging that prevents the car from being driven while the charging cable is connected and confirms a proper connection before charging begins
- Controls a 'soft' shut down to reduce the chance of electric shock or short circuits when disconnecting cables
Q
R
Range
- How far you are able to travel on the available energy in the battery and average MPGe
REEV
- Range Extended Electric Vehicle
- These vehicles tend to have a 'generator' engine running on gasoline or diesel fuel which charges the battery bank to run the electric motor(s)
- The Ram REV and the Scout Harvester package are good examples
Regenerative Braking
- sometimes called Re-Gen Braking
- A system that uses the turning of an electric generator with high tension to both slow down the vehicle and spin the generator (like an alternator) to crate electricity which charges the battery bank
- see also: Friction Braking
REX
- Range Extended Vehicle
- See REEV
S
SAE Combo
- Offering a standard J1772 plug with 2 additional DC connection points to enable Level 3 fast DC charging
- See also: CCS (combined charging system)
SoC
- State of Charge
- The battery's fullness from 0 to 100 (where 0 is empty/dead and 100 is full capacity)
SSB
- Solid State Battery
T
TSCN
- A large network of chargers supporting NACS charging
U
V
V2G
- Vehicle to Grid
- Allows your battery to communicate with the power company to control charge rates
- see also: Bi-Directional Charging
V2H
- Vehicle to Home
- Allows your car battery to act as a home battery back up system to power your home in a power outage
V2L
- Vehicle to Load
- Allows your car battery to power electronics directly via invertor to AC 120 or can sometimes be used to power/charge another EV directly
Vampire Drain
- The loss of range when sitting/parked, usually a percent or two a day
VESS
- Virtual Engine Sound System
- Artificial engine noise an EV emits over a speaker so that bystanders 'hear' the otherwise quiet vehicle at low speeds
W
WLTP
- Worldwide Harmonised Light Vehicles Test Procedure
- The global driving cycle standard for determining the levels of pollutants, CO2 emission standards and fuel consumption of conventional internal combustion engine and hybrid automobiles, as well as the all-electric range of plug-in electric vehicles.
X
Y
Z
