navguy12
Cheers.fair point on the no drilling
Just that I keep reading reviews on people saying after 3-4 hours of driving the lights flicker, must be because it gets too hot, I'll leave it as is since it fits perfectly in there, if not, I'll probably revert back to Halogen as well but better bulbs
As for the adapter, I'm at the office right now so restricted on printscreen but you can search below and you'll find it
So far it fit perfectly the Aukee LED bulbs, the advertising says its made for the RCP bulbs but that's not true at all. It also looks identical to the ones your LED kit comes with
RCP H7 LED Headlight Bulb Adapter Holders Socket Base Retainers for Kia Hyundai Accord, 2 pcs
Okay, seen.
Here is a screenshot of those adapters:
I'll have to wait and see how my headlamps perform.
I learned a valuable lesson when cutting holes into a 2008 Prius about 10 years ago, as well as "baking" the headlamp housings to remove the halogen setup and install HIDs....never again.
If these units show up and are not plug and play, I guess my wife drives with the OEM lamps...
