GPM432
try charging your old battery it may be good for more yearsThanks Kiwi, din44 it is then.
...the Yuasa LN1-MF which is a DIN44 AGM also but designed for EVs and hybrids.
Its still in the car and working ok. Touch wood.try charging your old battery it may be good for more years
Hi yes i fitted the din 65 to my Kona remove the four little ridges from the right hand side and part of the lip on the left hand as well, the support ribs for the weight are under the tray and are not altered at all, the battery is then a good fit and after 8 months is proving to be a good match for the on car charging systemThanks Kiwi, din44 it is then.
I use this one, also 1000 amp-works fineI’d like to get a portable jump starter - there are lots for 12 volt batteries - but their amps vary - does anyone know if a 1000amp one is safe to use on my Kona? (We recently had to replace our 12 volt - no big deal, but it seems like a good thing to have if the 12 volt goes sideways and the car will not start)
