electriceddy
Moderator
Follow this thread:For those of us still not conversant with the acronyms commonly used here, what’s the BM2?
Thanks.
https://www.insideevsforum.com/community/threads/installing-an-inexpensive-12v-battery-monitor.8391/
Thanks.
It reset my charge limits from 80% to 100%.Does this update reset the vehicle settings?
I took snapshots of the User Settings and the Setup menus, just to be safe. Going in tomorrow.
mine was reset too..It reset my charge limits from 80% to 100%.
I would think it would reset all menus to "factory default" .Does this update reset the vehicle settings?
The update did not reset all setting on my car (e.g., my regen level remained at level 3 where I set it).I would think it would reset all menus to "factory default" .
Which is not a really bad thing as it gives the opportunity to once again familiarize with the different settings.
I think that it only reset/changed settings related to the battery. REGEN also stayed at the setting that I had it set to even though driving mode was normal and not ECO when I got the car back.The update did not reset all setting on my car (e.g., my regen level remained at level 3 where I set it).
there is an article about it here: https://insideevs.com/news/428159/hyundai-updates-battery-monitoring-system-fire/On one Kona electric Facebook page, I am seeing people from Canada reporting they are being notified by their dealers that a Software Update to address a recall is available. One of them (not me) posted a photo of the paperwork that showed the following:
RECALL
HYUNDAI RECALL CAMPAIGN 00D005 S/W UPGRADE (BMS, MCU, VCULDC, IGP
I am in the US and I haven't heard anything about it yet from Hyundai or my dealer.
Does anyone here know more about this Recall and Software Update?
I actually booked mine in for July 3rd for that update and was told 1 hour to update, and another hour to wash the car.I got my update today and the GOM definitely went up. Mine is always high b/c I tend to get around 5 miles per kWh but I think it still increased about 7%. I was showing 298 miles on Econ mode at 99% battery.
I saw someone above ask how long it took, mine was basically an hour and a half but I did get the tires rotated as well. I forgot to look for aux battery saver, I think that's the item people said has changed for them. Actually I did go through the menus and didn't see that now that I think of it. I will refresh my memory where it's supposed to be and then confirm for sure if it's in my menu now.
Update: Ok yeah, confirming that aux battery saver is no longer an option on my menu. So I assume it's just always on or else the car determines when it's needed.
Unless I'm blind they didn't perform the High Voltage battery service. I just went yesterday and my receipt has a line item for:Just went for the service.
The AUX option is still in the menu and all of the settings did not change.
As a matter of fact, I seriously doubt they did anything on the software side.
I had the same kind of thing shown on my service receipt. I called them the next day and asked if they had actually done it since the receipt was unclear. They said their warranty system said they did...but I didn't get any temporary range increase which was mentioned (assume due to resetting something) and I just checked my cluster menu as well and found the aux+ battery saver is still there. Is there anyone who got the update in Canada that can confirm that the aux+ battery saver disappears from the cluster menu after the update?Just went for the service.
Just what has been reported here:I had the same kind of thing shown on my service receipt. I called them the next day and asked if they had actually done it since the receipt was unclear. They said their warranty system said they did...but I didn't get any temporary range increase which was mentioned (assume due to resetting something) and I just checked my cluster menu as well and found the aux+ battery saver is still there. Is there anyone who got the update in Canada that can confirm that the aux+ battery saver disappears from the cluster menu after the update?
Sent from my SM-G960W using Tapatalk
"2019-2020 Kona Electric (OS EV) High Voltage Battery Update
Cause: Performed Campaign 3 F
00D005R0 BMS & MCU & VCU & IGPM UPD.
996957 WH "
I don't see anything like that on yours
Didn't change any of mine - not even the trip odometers.I would think it would reset all menus to "factory default" .
Yes, it did that, although they showed up as 127% in the Bluelink app. I've seen that before.It reset my charge limits from 80% to 100%.
