KiwiME
John, had you installed the Votex plugs you bought last year? The iron and aluminium numbers are very low, nearly the lowest of any of the analyses we have so far at much shorter drain intervals.Here is the analysis ...
KiwiME, I had not installed the Votex plugs, beautiful though they are, having decided the external magnet method was more secure. So the reductiion gear oil had not had the benefit of any magnetic filtering at all.John, had you installed the Votex plugs you bought last year? The iron and aluminium numbers are very low, nearly the lowest of any of the analyses we have so far at much shorter drain intervals.
That would provide an interesting comparison.... I'll repeat the exercise on the newer car that has 11k Kms in any case
The bottle does show that stratified mix of clear oil and black particles that we've seen on:... I'm actually wondering if the dealer gave me back the correct oil.![]()
Here's my long sad story of getting the oil change at the Hyundai dealership - I’ll start by saying that I love this car! I had a bad experience buying the car and decided to try a different dealership for servicing. It took two appointments to get them to even do the oil change. First time I brought it in they did nothing. They told me the car didn’t have a transmission or any oil. When I disputed that they quickly changed the excuse and told me they did not have the right GASKET in stock so they had to order it. So I went to the parts dept. and they spent 20 minutes on the phone with Hyundai to figure out what to order. They ordered the gaskets and told me they needed it them in case the Votex plugs didn’t work for some reason and they need to put my OEM plugs back in after the oil change. They said they would call me when the gaskets arrived. No call – I called eventually and they had the gaskets. My second appointment was better since this time they did agree to do the gear oil change. But when I returned later they told me that the Votex plugs would void my warranty. So all I got was fresh oil. The invoice did not match what they told me so back and forth and another hour later they told me they replaced the fill plug but not the drain plug. They charged me for a new Hyundai magnetic drain plug saying it was ordered for me – which was not true, but at this point I wanted to leave. I get home and I see both Votex plugs are gone and I have two OEM plugs in the bag. They had installed them after all and they KEPT the drain plug I was charged for - you know, the one I didn't order. Why all the back and forth? I have no idea. But I have had it with them. So either I try a third dealership, find a mechanic who I can go to after the warranty is over or sell the car and get something else, although at this point I don’t know what that would be.Thanks for your contribution, Susanne. For 1st oil changes without a supplemental magnet the iron is slightly on the high side of the linear trendline but well within the scatter we've seen so far. It's not anything to worry about because by using a linear rate as a reference I'm assuming a linear addition of iron by distance driven which won't be accurate, more will be added during the break-in period, perhaps the first 1,000 miles. The magnetic plugs should do wonders to reduce iron levels from now on. Did the dealer do the oil change and was there any resistance from them installing the Votex plugs?
Aluminium is spot on average.
We have a 2021 Kona Ultimate
Does anyone know where the breather is for the reduction gear case?
I just purchased mine in December so only one winter's experienceI have noticed in a few YouTube videos of people driving the Kona EV in winter weather where snow gets under the charge door flap. It has those covers on the inside which should keep all snow out of them, but I was wondering if anyone has tried to put a foam seal on the inside of the door so that when it is closed it will be a bit more airtight (the stuff you put on your doors to make them not seep air).
The most obnoxious issue with the door is that water will migrate into the hinge and down into the mechanism and freeze forcing the door to be stuck in the open position. Because everything is made of (cold and therefore brittle) plastic there's really no way to force it closed without risking snapping the whole thing off.
My car is stored and charged outside all the time so the door is open and the car is plugged in 100% of the time when I'm not driving. That's when it's vulnerable. I've never had the hinge mechanism freeze while in the closed position (thank goodness!). It's the door gap that's vulnerable to freezing when it's shut. A sharp but restrained smack with a flat palm has always succeeded in crackung any ice in that spot - for me anyway. Your mileage may vary.Yikes! I didn't even think of that. The little flap-door our MX had would stay warm enough from charging to not have this happen (since if it was out and about and plugged in, it was charging). Thanks for the warning!
Here is one version:I have noticed in a few YouTube videos of people driving the Kona EV in winter weather where snow gets under the charge door flap. It has those covers on the inside which should keep all snow out of them, but I was wondering if anyone has tried to put a foam seal on the inside of the door so that when it is closed it will be a bit more airtight (the stuff you put on your doors to make them not seep air).
