dark night
hi on the 2022 module there are only too things in the wheel arch a brake pipe with brake fluid in it and the brake caliper electric check wire.
your thing looks thicker than the brake electric check wire, on your front parking system, is one of the sensors missing from its whole in the front of the car,
if so it looks like the sensor fell out when you hit the curb and then dragged on the road which caused the wire to rub through on the driveshaft, leaving what you have now, the only fix i know of is to have your dealer replace the sensor and reset the fault code in the cars computer,
