The following was posted recently by member Anaglypta on Speakev forum, its interesting info:
"That sounds correct based on some information that came my way (I've redacted identifying info to protect my source). this is a reply from a Hyundai Korea engineer to an email enquiry. The reply was in Korean and has been translated, so looses a little bit of clarity, but bears out what you've been told, confirms that Aux Battery Saver+ gets removed, and I'm guessing that NOTE 2 below confirms that 4 cumulative
REGISTERS get reset to zero (CCC CDC CEC CED) which gives weird
GoM readings after the update.
John
[Purpose]
This upgrade changes the high voltage battery sensitive and frequently checks for cell voltage deviation and insulation resistance,
so that problems can be identified and taken early in the event of a hazardous situation.
[Changed Logic]
1. Proceed the upgrade, the cell deviation and insulation resistance measurements become sensitive.
1) Cell deviation)
- Before : Detect problems when voltage deviation is higher than 1V.
- After : higher than 100mV (Level 1) / higher than 150mV (Level 2)
2) Insulation Resistance)
- Before : Less than 300kΩ
- After : Less than 900kΩ (Level 1) / Less than 700 kΩ (Level 2)
2. The inspection cycle will be changed as shown below.
- Before : Check the condition of the vehicle once 24 hours after starting off)
(At this time, check the condition of the 12V battery to support charging
from the high voltage battery if the SOC is insufficient)
- After : Monitor the vehicle condition for 2 hours in a row after starting off, then check the condition of the vehicle for 4 hours. (Total of 2.5 days)
* Check for 2 hours in a row for the first time only
* Check the condition of the vehicle once every 24 hours after 2.5 days.
* Check auxiliary battery SOC when monitoring the condition for supplementation.
* NOTE 1) As a result, the dark current can reach up to 300 mA even after starting off.
Based on the logic above, it will be lowered to 50 mA level after 2 hours.
* NOTE 2) In some cases, it is reported that the four controllers are discharged after updating them.
This may occur if the vehicle is parked in a short drive with a large number of auxiliary battery SOCs.
* NOTE 3) In some cases, you may be asked that the battery charge function button is disappeared in the cluster.
When vehicle monitoring starts, the 12V battery SOC is also checked at all the time.
then if insufficient, The auxiliary battery is charged. (The charge logic is always active.)"
https://www.speakev.com/threads/kona-ev-recall-in-korea.153828/#post-2900846
