PSA: Recall for HV Battery
  • Thread starter Thread starter inferno10
  • Replies Replies 372
  • Views Views 47K
Another went up in the UK a few days ago. This is the 3rd YTD. Apparently it didn’t have the software update which honestly is just a bandaid solution. The car in photos display check HV Battery and drivetrain malfunction before going up
We have pretty much decided that we aren’t keeping our 2023 SE when the lease is up. Mini needs to launch a complete battery recall
View attachment 28859View attachment 28860
For an EV that's had a battery fire, it's remarkably intact. Usually it's hard to tell what it was.
That looks like it got t-boned and then the fire started, nothing to do with charging. The photo with the flames doesn't look any worse than a gasoline fire. Also curious to see the bonnet popped open, there's nothing under there except the motor, heat pump, and 12 V battery. Is that emergency response protocol?
When I had my F56 SE, I remember seeing an "emergency cut" wire under the bonnet on the driver's side, near the windshield. I assume that's some kind of safety disconnect or way to trigger the traction battery's primary fuse.
the mental gymnastics over a platform that has a serious fault is hilarious. The F56 SE needs a recall not a software update
That's what I was going to mention.
As you may know, there's also a disconnect under the access panel for the right taillight. That one you can pull partway apart for, e.g., service then push back together to reconnect.
Initially counterintuitive to me is how small the wires are, but it makes sense when you realize that these disconnects apparently just isolate the battery controller, so that high current doesn't flow (unless there's an active short).
For sake of argument, let's assume that this was indeed a spontaneous battery fire, and not the result of a collision.
Let's also assume that there were indeed two other such incidents in the UK earlier this year (although I don't know where you're getting that information).
AFAIK, the software update to enhance battery monitoring was the result of two fires.
So, that's five, out of a total production of over 140,000, or 0.004%.
At what point would a recall to take additional steps be warranted?
That's not a rhetorical question, but also one that I'm not sure I know the answer to.
I suppose a couple of really big considerations would be:
1) are fires limited only to those couple/few hundred SEs with batteries that weren't sealed properly, and
2) did any fires occur in vehicles that received the software update, which failed to flag a developing problem? (If the owner ignored the warning, that's another story.).
If 1, then the failure rate is much higher, but it would seem that the cause has already been identified and the issue has already been successfully addressed (unless some resealed battery catches fire due to water ingress).
Same if not 2.
OTOH, If not 1 but if 2, then perhaps some additional actions are warranted (or not).
Point being, there's too much that we as consumers don't know to draw any valid conclusions even if humans were capable of accurately judging risk (which we aren't).
ETA: According to Google AI, high risk industrial plants target an annual risk of catastrophic equipment failure of, coincidentally, <0.004%. Thus, if there have actually been five fires and the issue hasn't already been successfully addressed (see above), then it would seem that the situation may be on the cusp of requiring further action. However, both of these conditionals would have to be true. Otherwise, this standard hasn't been exceeded.
This Ev looks to good for HV battery fire as tires are still inflated
Same if not 2.
And if it caught on fire in your house? The fact there is a software hack indicates an issue. Frankly I never liked this approach as it’s a bandaid solution
