the mental gymnastics over a platform that has a serious fault is hilarious. The F56 SE needs a recall not a software update
For sake of argument, let's assume that this was indeed a spontaneous battery fire, and not the result of a collision.
Let's also assume that there were indeed two other such incidents in the UK earlier this year (although I don't know where you're getting that information).
AFAIK, the software update to enhance battery monitoring was the result of two fires.
So, that's five, out of a total production of over 140,000, or 0.004%.
At what point would a recall to take additional steps be warranted?
That's not a rhetorical question, but also one that I'm not sure I know the answer to.
I suppose a couple of really big considerations would be:
1) are fires limited only to those couple/few hundred SEs with batteries that weren't sealed properly, and
2) did any fires occur in vehicles that received the software update, which failed to flag a developing problem? (If the owner ignored the warning, that's another story.).
If 1, then the failure rate is much higher, but it would seem that the cause has already been identified and the issue has already been successfully addressed (unless some resealed battery catches fire due to water ingress).
Same if not 2.
OTOH, If not 1 but if 2, then
perhaps some additional actions are warranted (or not).
Point being, there's too much that we as consumers don't know to draw any valid conclusions even if humans were capable of accurately judging risk (which we aren't).
ETA: According to Google AI, high risk industrial plants target an annual risk of catastrophic equipment failure of, coincidentally, <0.004%. Thus,
if there have actually been five fires
and the issue hasn't already been successfully addressed (see above), then it would seem that the situation may be on the cusp of requiring further action. However, both of these conditionals would have to be true. Otherwise, this standard hasn't been exceeded.
