I've always wanted to know this. I have a dedicated Level-II EVSE that I use at home (I rarely charge anywhere else) but it would be nice to press my OEM charger into service at a Campground or RV hookup while travelling. Most KOA facilities have a NEMA 14-50R receptacle.
Naturally, the 100% safe way of doing this is to buy an inline EVSE with the right plug, but then my OEM unit will hardly ever be used. Besides, I'm cheap, and do not want to spend another $300+ for an aftermarket EVSE. I may just roll the dice on this. The worst thing that will happen is that I smoke my Honda OEM EVSE, which would be a pity, because the thing is built like a tank.
In theory, it could work. I have built EVSEs and I am also an electrical engineer. The main components of any EVSE are:
1. Heavy-Duty Relay (contactor) that connects the AC Mains to the vehicle. It turns on and off via an electromagnet (coil). The heft of this contactor is determined chiefly by the rated current. The higher the current, the beefier the contacts must be to safely carry it. The applied voltage determines some of the physical dimensions of the contactor parts like spacing and creepage distance. The vast majority of relays used in these types of devices can safely switch up to 250VAC at the rated current.
2. Protocol Controller: This is a microprocessor-controlled circuit that "advertises" to a connected vehicle how much current can be safely supplied by the EVSE. That information is used by the vehicle's onboard charger to set an upper limit of how much current will be drawn by the vehicle. The Protocol Controller also detects when the EVSE is plugged into a vehicle and performs all of the sequencing and control activities that eventually result in energizing the contactor coil.
3. DC Power Supply. This is a switching power supply not unlike the one used to power a laptop PC or a smartphone. It takes the AC Mains voltage, and converts it into a regulated low-voltage DC for powering the Protocol Converter, and in turn, the contactor coil. Most modern power supplies are capable of accepting a wide range of input voltages, typically 100VAC to 240VAC. The DC output voltage is always the same.
Now, for the OEM charger:
It makes sense for an OEM to have as few versions of a device as possible to hold down costs. Computer manufacturers have been doing that for years. An external power supply for a Lenovo laptop PC is exactly the same the world over. The only thing that changes is the removable power cord that is plugged into the outlet of whatever type and voltage exist in your country. Anywhere in the world, that voltage will be between 100 and 240V. For this reason alone, I strongly suspect that the Honda OEM EVSE is designed that way.
To make a Universal EVSE (100-240V) you need only:
1. A DC power supply with universal input.
2. A two-pole contactor. In theory, a single-pole unit is sufficient to cut the current, but for safety's sake, both current-carrying wires must be interrupted when switching power on and off for North American 240VAC systems.
Since the Protocol Controller operates entirely on low-voltage DC, it has no awareness of the Mains voltage if the DC is coming from a Universal power supply.
The pilot signal will still "advertise" a maximum current of 12A, (for most OEM Level-I EVSE). If, however, the EVSE is plugged into a 240VAC mains, the contactor will now switch 240VAC to the vehicle, and you will charge twice as fast (same current, twice the voltage = twice the power).
About the Plug:
The Honda OEM charger comes with a NEMA 5-15 standard plug for 120VAC circuits. This is the same type of plug you will find on common household appliances. There is a twist, however. The plug has embedded inside, a sensor that monitors the temperature of the two current-carrying blades. If they get too hot, it will cut off the charger. This is a safety feature to prevent outlets from overheating. Outlet contacts wear out with time and become loose, increasing the resistance of the connection which makes them get warmer as more current flows through them. The EVSE will draw 80% of the maximum rated capacity of a brand-new NEMA 5-15 outlet, so there isn't much wiggle room. If your outlet is old and flabby, it will get hot quickly.
This means that the OEM plug CANNOT be removed and replaced with a 240V plug, such as a NEMA 6-15. Without the temperature sensor, the charger will not operate, and it will present a safety hazard besides.
I examined my charger and noticed that the input cord (pigtail) is removable, much like the power cord on a computer power supply. To remove the cord, the cover must first be removed. I have a set of 3-point security screw bits, so that was easy. Once removed, depress a little locking spring, and screw off the connector at the box. The pigtail pulls right out, revealing a weird, proprietary 5-blade connector. (Two for the current-carrying wires, one for the safety ground, and two for the sensor) Certainly, other pigtails could be offered by the OEM to suit different kinds of outlets. I have looked high and low for a 240V pigtail that will fit the box, but have been unsuccessful so far.
Now, if one is brave (and doesn't mind creating a major electrical code violation and possible safety hazard), they can make a home-brew adapter as follows:
1. Get a 240V plug, such as a NEMA 14-50
2. A short length of 12/3 portable cord
3. An inline NEMA 5-15R receptacle
Use the green wire to connect the Ground pin of the plug to the ground pin of the inline socket.
Wire the two Hot contacts of the plug to the remaining two contacts of the socket. (THIS IS A BIG NO-NO by the code book because the silver screw is supposed to be neutral, never hot. Do this at your own risk!)
Leave the Neutral contact of the 240V plug unconnected.
The stock NEMA 5-15 plug on your EVSE will mate with the socket on your adapter, which will now supply 240VAC to the two current-carrying conductors.
Rolling the dice:
When you plug the adapter into a 240V outlet, one of two things will happen:
1. You will learn for sure if the internal DC power supply in your EVSE is capable of functioning on 240V. If it's not, you will immediately smoke the charger. Most likely, the worst thing that will happen is that an internal fuse will blow. It is highly unlikely that the unit will catch fire, but you'll now have a $400 brick.
2. The EVSE will work like a champ, and happily send 240VAC at 12A to your vehicle, charging it at twice the rate. (2880 Watts, or about 8 miles/hour).
Now- there are two practical problems with this approach:
1. The adapter is a hazard if someone attempts to plug some OTHER 120VAC rated device into it. The device may be damaged, and there could be a shock hazard. This is why 240V plugs have a different blade configuration.
2. The built-in sensor will still detect a hot plug, but will have no awareness of the 240V plug blade temperature. That is not likely a problem, because a NEMA 14-50 plug can carry 50A, so it would have to be really worn-out to get hot at a measly 12A
For a chart of common NEMA flat-blade plugs:
https://www.menards.com/main/buying...s-connectors-buying-guide/c-1467312433250.htm
