megreyhair
My AC is still working on a '18 (knock knock knock knock on wood).
Hopefully you still have enough refrigerant in the system for them to find the leak. That's something I learned on my repair. Since I had gotten down to 3.8 psi at 60 something, there was not enough. I was quoted something like $175 for diagnostic and $325 to charge the system. Fortunately charging it showed the leak right away and it was all covered under the extended warranty.To chime in as well:
2018 clarity PHEV, ac worked fine until summer 2022, when condenser was replaced twice (under warranty, thanks to this forum). Over winter became suspicious that it was losing cooling/dehumidifier power. Definitely the case now, so sending back to dealer tomorrow.
I had assumed that it would be impossible for *two* replacement condensers to fail, but from the above seems like that does in fact happen. We’ll see. I’ll post a followup once I have a diagnosis.
Thanks also to this forum, I can see that refrigerant pressure is 24 psi at temp 68-77 which is far too low. Nice to be able to check these things.
If you live in a state that doesn't have a lot of road corrosion, you might never have an issue. I live in Michigan and corrosion is an issue.My AC is still working on a '18 (knock knock knock knock on wood).
I live in NJ so tons of salt. Maybe not as much as Michigan but still plenty. But in the last few years, my area start using brine to pre-treat the roads so less rock salt were applied during storms.If you live in a state that doesn't have a lot of road corrosion, you might never have an issue. I live in Michigan and corrosion is an issue.
Where exactly was the drip? Was it near the driver side or passenger side?Although the AC is working on our 2018 Clarity Touring (October 2018 build), I noticed oil on the bottom of the plastic underbody beneath the condenser this past weekend. There were two small drips on the garage floor. The bottom of the condenser had oily dirt on the fins, too. We took the Clarity to the dealer this morning and they diagnosed (at no cost) a failed condenser. The condenser needs to be ordered and will be replaced under the warranty.
I am surprised at the amount of oil that leaked out while there was still enough refrigerant to allow the AC to work. The leak looks to be at the bottom of the condenser and that probably makes for a higher oil to refrigerant ratio for the leak. The static AC pressure was at 85 psi when I checked yesterday and this confirms that there was still liquid refrigerant left.
LeoP
I believe you're referring to the ClarityScreen from Voltstuff.I also purchased a mesh guard from someone on these forums to protect early on...
Perhaps there were so many defective condensers that Honda decided to recoup some of their warranty expenses by selling them to a remanufacturing company who's now reselling them as aftermarket parts.By the way, I think it is interesting that there are after market (not Honda oem) AC condensers available for the Clarity now.
I assume Honda continues making faulty new condensers rather than buying repaired units to install under warranty.Would Honda then have to buy them back from the “remanufacturing” company in order to supply them to dealers for warranty claims? And, who would pay for a part that is covered under warranty? Both companies would stand to lose their shorts on that deal.
Now, if they were government organizations they would simply charge the taxpayers for their stupidity.
Sorry, how did you see refrigerant pressure?To chime in as well:
I have a 2018 as well with about 70,000 miles. Brought it to the dealer about 3 weeks ago as I had hit air coming out during AC usage and they replaced everything for free.... cold AC now. Everything involved with getting your AC running again should be covered.
