Robert_Alabama
@Casey Martin ... You are doing better than me. I'm at 45.62 Ah with 42,250 miles (about 26,000 electric miles) also on a 2018.
How do you know how many miles were electric? I didn't explore all the lines on the Honda IDS. Maybe it shows that data?@Casey Martin ... You are doing better than me. I'm at 45.62 Ah with 42,250 miles (about 26,000 electric miles) also on a 2018.
Same. I tried to also keep track of charging, but some public stations don't report the KwH, so I mostly gave up.I track all the gallons of gasoline I put in the tank and assume 40 mpg (I keep a spreadsheet of gasoline purchases). This lets me say the rest of the miles are electric. Approximation, but probably pretty close. It's just a nerdy thing to do, but it lets me keep an idea of savings of electric vs gas and hours of operation of the gasoline engine (from assuming an average speed when running on gasoline).
where is the post with the step by step procedure to do this again?
Funnily, after charging the GOM gives me 57 EV miles of range...
Does the calculated battery capacity drop in time regardless of the usage?
I first checked January 6 and got 48.88, now January 22 I get 48.80. I haven't used the car much since, only a couple hundred km max.
Does the computer just keep dropping the capacity based on the age of the battery?
We are only guessing precisely how Honda Engineering mechanized this... But,Does the calculated battery capacity drop in time regardless of the usage?
Looks like a pretty solid unit, beats one of these universal/multi-purpose ones:My wife took the Clarity to work today. I will try to remember to take a photo and post it later tonight. But in the meanwhile let me give you the link to the mount i used.
Phone Mount, MOKPR Universal Car Mount with Long Arm Dashboard Windshield Car Phone Holder and Strong Suction Cup Car Phone Mount Anti-Shake Stabilizer Phone Holder for iPhone, Galaxy, Pixel, Moto etc https://a.co/2LBzNVI
@MrFixit could you update my readings? I am scared that I will mess up the database. My battery capacity readings (Clarity Touring 2021) have gone up to 54.80 (from 53.80 in September 2022). Odometer 10,214 miles. Since my last reading that I sent you, my 12 volt battery had drained (over the Christmas break while I was away for 4 weeks and I had forgotten to turn off the dash cam) which necessitated the use of a 12 volt Li-Ion jump starter. I did not take a battery capacity reading right after this.
Happy New Year [again], and thanks to everyone for their interest in helping to characterize the HV battery longevity of this great vehicle !!
Thanks to all, our data accumulation effort has been phenomenal! Don't forget to check out the results of this ongoing effort by examining the shared spreadsheet.
This year, A forum member who is very talented in statistical analysis has contributed a new graphical analysis viewpoint. There is a link to this from the shared spreadsheet, or you can get to it directly here: Thanks to Thomas Clauser !
Statistical Analysis Here
Here is a link to the Shared Spreadsheet. The Introduction Page has instructions and links to data entry and all of the graphical results:
Shared Spreadsheet Here
If you are already a participant, but haven't done a measurement for a while, the start of 2023 is a great time to pull out the OBD tool and add a fresh new reading to the data set !!!
Thanks again for all of the interest
I finally found some time to make some changes to the analysis focusing on forecasting an accurate capacity reading based on all the data (which can now be found on the second page).
