A big thanks to all of those that have contributed to this thread so far! Thanks to you, I was able to install the switch with no issues. To give back a little, I thought I'd add in a couple of images that might help others do the same and maybe even make the task a little easier.
1. Create Switch Assembly
First up, it looks like I ordered the same momentary push switch, with LED light, that many others have ordered from Amazon. Shown in (image)
1A is my wiring diagram, and how the switch connects to the "blue " (really blue with a black stripe) and "pink" wires on the wiring harness. (Image)
1B shows the data sheet that came with the switch. I didn’t use any of their wiring examples because none of them matched up with what I wanted to do.
1C shows how I soldered the wires in. It came with a plug that plugged into the back of the switch, but I chose to solder because I was worried about the depth of the whole thing near the fuses (In retrospect, I probably didn’t need to worry, and it would have been nice to be able to unplug that if I need to bring the car in for service). The wires I used are slightly too big (gauge-wise), but that is all I had sitting around. You can also see how I used heat-shrink tubing to insulate all of the wires individually. Then I used a larger heat shrink tube to insulate everything and provide some strain relief as shown in
1D.
1E shows me testing the LED light using a typical healthy battery voltage of 13.2V. From the data sheet, it wasn’t clear whether you needed to add a resistor, but this confirmed I didn’t need one.
2. Install Switch in Fuse Panel
With the switch assembly done, I decided to install it in the fuse cover door that is found near your left knee when sitting in the driver’s seat (in the US at least). Seemed to me that the fuse panel would be easy and cheap to replace when my lease is up, and that location is easy to reach while driving. I drilled a hole in the door where I could still read the fuse diagram on the back. These images show where I drilled
(2A), what the hole looked like after drilling (
2B,2C), and what the switch looked like installed (
2D, 2E). I really recommend this tapered type of drill bit for drilling big holes in plastic.
3. Open Up The Dash
Next up was opening up the dash. (Image)
3A shows the use of a plastic automotive trim pry tool (Harbor Freight) to open up the side panel. Rotate the panel open like a door (
3B). You don’t have to remove that piece of plastic, just leave it sitting there, rotated open. Use a screwdriver to remove the two screws (see yellow circles in
3B and also
3C) that are now exposed. Then pull the bottom panel away from the dash as shown in
3D &
3E. Notice the “hooks” in the switch panel above… that hooks into the “tabs” in the bottom panel. This is why you need to pull the bottom panel out a little… just enough to let the switch panel above it clear the tabs in the lower panel.
Not sure of the etiquette, but to keep a single post from becoming too long, I'll continue in the next post...
