How to disable VESS (Virtual Engine Sound System) on 2020 (US)
Discussion in 'Kia Niro' started by Nelson1994, Sep 21, 2020.
  1. ENirogus
    ENirogus Active Member
    In parking lots I have taken to letting it bong once, then shutting it off
  2. Danhen
    Danhen Active Member
    Anyone know what he is talking about? I can't figure it out.
  3. Danhen
    Because my neighbors are dropping hints at how "cute" the forklift sound is. They are trying to be polite and diplomatic. I know when to take a hint. They don't think the sound is cute.
    Kendalf likes this.
  4. Jack W Kielsmeier
    Jack W Kielsmeier New Member
    I have a 2020 EX Premium. I "think" I see the connector but want to be sure. I made a quick video as to what I think I need to unplug. Is this correct?
    Robert Bratton likes this.
  5. Jack W Kielsmeier
    It is the shown connector. You can use the straw kri mentioned above to unlatch it. I couldn't pull it up with the straw, but I was able to reach my hand in there and pull it up.
  6. midnightrider
    midnightrider New Member
    I just bought a 2022 Kia Niro EV. The reverse sound was like a dump truck in the driveway. My wife said to turn it off. Ok. I decided the disconnect approach was my best option. I followed the instructions on the post prior to remove the front bumper, with the proper tab removal tools (Amazon), and I got to the last step which was to removed the bumper. I elected to try to remove one side only and put my hand in and remove the connector. With a bit of courage and a quick but firm pull, I successfully parted the right side of the bumper from the vehicle with only a tiny, tiny plastic piece as collateral damage. I pulled the VESS connector off with a pair of needle nosed pliers and carefully re-assembled the bumper and bottom separator. It disabled the sound, and with no warning light (so far). I considered wiring in a switch, but I would have had to chase down a wiring diagram, and a lot more work. I've decided that a quick tap on the horn when I'm backing in a parking lot will do just fine as an alternative the the overly loud and obnoxious reverse chime.
  7. ENirogus
    funnyperson1 likes this.
  8. BillX
    BillX New Member
    I have a 22 Niro and like many are not happy with reverse noise. People here have stated they have successfully disconnected the connector via accessing in the gap under the hood, apparently either with a metal straw, a long screwdriver, or even their hands. I have tried to disconnect but so far have not had success...I am having trouble unlocking the connector with my hand or tools. I have torn up my hand pretty well reaching under there. Just to confirm, where is this tab on the connector that must be pressed? It is facing away from front of car I assume? Is it pretty low down on the connector? How much force is needed and how wide is this tab? Frustrated...it is seems like others didn't have any problems, at least not that they mentioned. My hands are pretty large...Thanks.
    LegoZ likes this.
  9. Kendalf
    Kendalf Active Member
    On a FB Niro group that I'm part of, one new US 2022 owner claimed that the reverse sound didn't seem that loud. I'm just curious if KIA has indeed lowered the volume for 2022. Could any US 2022 owners compare the volume to the 2020 model in this video? I know it's difficult to really compare to a video, but in the video the horn is honked in the middle to give some reference for relative volumes.
    Tagging the ones who recently posted as 2022 owners on the reverse noise threads: @BillX @midnightrider @Lagsun
  10. Crash
    Crash Member
    Would say just as loud for 2022.
    Kendalf likes this.
  11. BillX
    BillX New Member
    Agree, but cannot say for certain without hearing them side by side. 2022 seems too loud to me.
    Wish I could disconnect the connector like some here have done easily it seems.
  12. BillX
    BillX New Member
    Success! Just using my fingers I was able to unlock via pressure on top part of connector, hear click, pull up, and remove. No more bothering neighbors or family members in early morning.
    Derrydave likes this.
  13. Uscolt45
    Uscolt45 New Member
    I tried looking for the wire on my 2022 Niro EV and can’t seem to locate it. Any chance you could take some better pictures of the location or maybe FaceTime to help me out? I looked at the video above and can’t seem to find a wire that looks the same. Tired of listening to that crap lol.
    Thanks
    Bryan
  14. Uscolt45
    Uscolt45 New Member
    Disregard I figured it out. What helped me was disconnecting the radiator bolts and prying it away from the front plastic “frame”. Easily fit my hand in there after that. Also removed the hood latch assembly. I was looking downward in the radiator and not seeing the wire. Realized it was forward of the radiator reaching towards the Kia logo on the front bumper, in the 1” gap.
    Pic of the radiator bolt to remove, one on each side.
  15. Robert Besen
    Robert Besen Member
    I put in a fuse bypass switch to enable/disable the backup "chime" but I wonder if anyone knows what the other function on that fuse, BATT_COOL_EXV, does. Is it a warning, or is it needed to turn on battery cooling when needed, or something else? Anyone have a shop manual that sheds light on this?
    Robert Bratton and BarryP like this.
  16. BarryP
    BarryP New Member
    I'm interested in this too.
    -Barry
  17. That controls the cooling fan for the 64kWh battery. I know it kicks in when fast charging on warmer days at high speed (it is noisy). I do not know if it kicks in more quietly under ordinary operation
  18. rcnesneg
    rcnesneg Member
    Can confirm 2020 US Niro EV EX Prem is same volume as 2022 US Niro EV EX. We have both.
  19. Justinf
    Justinf New Member
    I found a fuse bypass switch online that allows me to turn the VESS off via the fuse when the noise is a nuisance (like backing into or out of my garage), but then turn it back on in all other situations! It’s been working well for me!
    Blue Ox BX88271 ATM Fuse Bypass Switch with Short Lead https://www.amazon.com/dp/B009APJ2UU/ref=cm_sw_r_cp_api_glt_i_BQV268C398W8AAJ03MCT
  20. aryehzev
    aryehzev New Member
    I paid someone to remove my bumper and unplug the connector. It took him 20 minutes.
