Toolworker
All of the above. The Android Auto app displays a different set of gauges from the ones in Torque. You select 1 to 6 of the type shown in my photo, with some configuration options. You can pick from the PIDs (sensors) in Torque, including any additional ones you have loaded.Regarding step 5, the displays (gauges) in Torque are not sent to the screen? You in effect have a different set in AA? Or are you choosing only from gauges in use by Torque?
Having used this a bit more - the first time I tested it, the gauges all worked fine. The second time I had Google Maps navigation working too, and the power gauge only updated about half the time, the speed gauge not at all. I'll have to try it again without navigation to see if this is repeatable.
