rickyrsx
Mine were installed before delivery! Shout out to Parkway Honda.
Thanks to @Atkinson for sending me a treasure trove of docs he found on Honda Tech. The best of the lot is the attached Pre Delivery Inspection (SB 17-093) that lists a lot of info not previously sourced on the forum.
Here are some of the highlights:
[snip]
4. It says to install 4 body plugs (under car just behind front wheels and just before rear wheels and has a picture). It says “they are part of the noise reduction package and play a big part in reducing road noise”. I checked my car and they were not installed! I have my dealer ordering them now. So I have little faith that the pre delivery inspection was done correctly. You might want to check your Claritys for this. They fit in oblong oval holes (maybe 1x2”) about 6” from the edge of the sides of the car.
Spot on. I drove for months before I knew about them and had dealer install them. I found they only seem to make a small difference.Mine were not installed, so I did that this afternoon. My silly question is how do those four little rubber plugs reduce the road noise? There were lots of other small holes in the underside.
It seems like Honda is really dropping the ball on this simple pre-delivery inspection. Or is it solely the dealers' faults for doing such a shoddy job? I picked up my Clarity yesterday. They did leave the checklist in the glove compartment. There are check marks on those tiny boxes for items from section 1 through 9 that were signed by the technician. Don't see the body plugs installation as one of these items. The last page, section 10, was checked off, but the page was not signed by the dealer. The biggest issue was that the day before delivery, they told me the car wasn't available because they have to finalize all the inspections and they were going to fully charge it and to come the following day for delivery. But it was not charged. There was barely 2 bars on the battery. They also used my charging cable to charge. I know this because the sales guy pointed to my charging cable hanging outside the dealer's exterior wall and told me the car was plugged in and was charging, someone must have unplugged it. And that he moved it from the charging spot because cars sometimes get damaged and dinged up over there. I am like "What?" and he didn't bother to check whether the battery was fully charged before moving it or early that morning when he texted me? I picked up the car in the late afternoon. It was also missing the charging cable bag. It just didn't give me a lot of confidence that the dealer knows much about this car or perhaps they don't care.
20. Charge the High-Voltage Lithium-Ion Battery The high-voltage lithium-ion battery should be charged only after all other PDI items are done. To save time, you can use a Level II 240-volt AC charger. NOTE: Do not use the portable charging cable stored in the trunk to charge this battery; it is strictly for customer use. If needed, order one or more of these charging cables from Honda parts stock as a service tool for your shop. Order P/N 1T210-5WJ-A01.
Hey KentuckyKen,The “real” Clarity PDI is Service Bulletin 17-093 and is 13 pages long. From what you describe, they used a Clarity pre-Inspection doc that is similar to the ones used on all Hondas.
It is not very specific to a PHEV Clarity and omits many items such as the 17kW Battery Capacity Signal, and the body plugs, just to name a few.
I bought mine in Feb and they used the more generic one and when I went back with the 17-093 one, they said that it came out in March so they didn’t have it for my car.
I had them check the Battery Capacity Signal to make sure the battery was not damaged by not being charged for a long time and had the body plugs installed. The Battery Capacity Signal is a nominal 55 Amp hours. Mine read 54.7 at 3 months after purchase so I think I’m OK.
Attached is the 13 page SB 17-093 PDI so you can see what they should have done.
Now that you say that, the pdi checklist I have does mention in the header that it's the Clarity checklist and not one that applies to all Hondas. However, its still different than the one KentuckyKen posted..and it doesn't have a spot for the charge capacity..just some 10 digit code which isn't informative (at least to me)The plugs are not unique to just the Clarity, Civics and probably others have them as well. They are PDI installed as holes are left open to secure the vehicle during transport.
That makes sense. I just bought my Clarity in September but since the bullitin came out in March my dealer really should have taken care of it. I'm not surprised though. They also missed the plugs but still managed to check them off on the pdi. Thankfully we have this forum. Looks like I'm going back again.The 10 digit code is just for the 12v battery. It’s just proof that the battery meets the minimum specifications to be considered a “good” battery; for example cold cranking amps.
Only by the dealer using their Honda diagnostic tool and checking the Battery Capacity Signal can you know the health of the 17kW HV or traction battery pack. Nominal value is 55 Amp hours. Warranty replacement is when it reads below 36.6 Amp hours. I had dealer check mine at about 4 months and it read 54.3 Amp hours. The 13 page PDI is how I found out about the 17 kW battery check, the 4 plugs, and the high tire pressure that dealer was supposed to reduce to 36 psi.
Roast your dealer alive on the customer satisfaction spit!The service advisor said that the service department could not check the amps on my Clarity with the I-HDS diagnostic tool. I asked that it be checked (to see if it’s near the 55 amp hours), and his response was that the car will tell me if the battery is not holding a charge adequately. Is it possible to use this tool to determine the amp hours? I also have not completed my initial customer satisfaction survey.
