Roast your dealer alive on the customer satisfaction spit!
They are either lying or totally incompetent. The car will NOT tell you when the traction battery is not holding a proper charge. In fact It won’t even throw a diagnostic code when the battery gets below 36.6 Amp hours and is due for a free warranty replacement! Your dealer is lying through his teeth. Ask him for the documentation on that and watch him or her draw a blank.
Why does the customer have to teach the service department the basics of this car? That is truly sad.The salesman owned a Clarity himself and mostly knew his stuff pretty well, but I don't think they'd ever encountered this request before. Since the vehicle was just 20 days off the boat from Japan I wasn't seriously concerned, but the more the dealership resisted getting me the information, the more I wanted to have it. They did do what I wanted without more than 10 minutes of back-and-forth, so I'm not going to ding the salesman's rating for it.
N.b. per LegoZ's comment above mine, my PDI also had items like navigation and compass checked off even though it's a Base model.
According to my dealer (and take that wirh a grain of salt), the Clarity Specific PDI that I started this thread with came out in March of 2018.Thanks for this information!
I just checked the bottom of my new clarity and found only 2 of the holes were plugged (maybe they took the other two for something else...?)
I did not receive anything resembling PDI Checklist when I signed the lease recently. Should I ask the dealer for a copy (if they even have them)? Is this something they have to provide to the customer?
55 Amp hours. It states that warranty replacement is at 36.6 AhWhat should/would the "Battery Capacity Signal" be on a good new battery pack?
Note that temperature may slightly affect the readings.
Nope. You got it.So, looks like 33% loss is Honda's definition of acceptable battery capacity degradation, unless the 55Ah implies a battery capacity of more than the advertised 17kwh. am I in over my head?
It's really strange that the dealers still don't know anything about these plugs. A friend of mine bought a Clarity (she had to listen to how much I liked mine every day). I told her to tell them to reduce the air pressure in the tires and install the sound reduction plugs. The service manager made it a point to get the salesman to tell her the plugs weren't needed here. They said they only fill the holes to help keep salt and grime out in the north where winter weather is bad and that they have nothing to do with sound reduction. This is the service manager at a relatively rural Honda dealership (small city).
I just don't get it. How long does it take to install those plugs ... five minutes, maybe? So why not do it just in the interest of customer satisfaction. The more I read about how clueless the dealerships are, the less I am likely to ever buy another Honda product. Although the dealerships for the other brands may be even worse ...
In my case, the plugs were installed, and I simply got use to the added noise over rough roads. I am more than happy to do so knowing the tradeoff is better fuel economy. The real issue is that LRR tires are reported to be poor in snow and ice, and adequate to good in wet (not exceptional).I just bought a Clarity and like many it was really loud inside. A lot of road noise particularly on worn highways with a lot of aggregate visible. I checked yesterday and the plugs are installed (I just checked the drivers side, will check passenger side today) BUT my tires were at 50+ PSI. My little gauge only goes to 50PSI. I let about a 3-5 second blast of air out to get DOWN to 50PSI. Door jamb says 36PSI so I dropped them down to a smidge over that (it was 97 degrees yesterday) and this morning the commute was substantially quieter. Though I still think there is a lot of road growl.
I see the posts where one person says it's load and the next post is someone saying the clarity is the quietest car they've ever owned. And yeah it's subjective and likely very dependent on what you were driving before. I had a 2011 Toyota Highlander Limited. It was VERY quiet inside. I'll continue to monitor as the tires are barely broken in too (I'm at about 500 mi).
