We are ready to offer additional PID's that provide quite a lot more functionality.
Since Torque has the substantial problem discussed above, these new PID's are packaged for use with Car Scanner.
** Important ** We had to get the Car Scanner developer to tweak the import / export functionality to enable this to work completely. He has a public beta for this on the Google Play store, and you will first need to update your Car Scanner to that version (Currently version 1.75.9). I presume he will release this once validated. You can google to learn how to access a public beta version... Not clear how long before he will release this officially, but hopefully we will know when he does.
** One Other Note ** - Somewhere along the way with adding all this functionality, Car Scanner advised me that I had exceeded some limit of the free version and I had to upgrade to Pro. I don't know exactly what triggered this, but It was only $3.99 and the developer has been very cooperative with us. I submit to you that it is well worth it to have all this functionality for your vehicle ! So, you can try the free and see if it works for a while or just upgrade from the start.
This functionality includes the following:
- Battery Capacity (Total)
- Battery Capacity (Just Bank B)
- Individual Cell Min SOC (Line A)
- Individual Cell Max SOC (Line A)
- Individual Cell Min SOC (Line B)
- Individual Cell Max SOC (Line B)
- Overall SOC
- Air Temperature Inside Vehicle
- Air Temperature Outside Vehicle
- Transmission Temperature
- Individual Cell Voltages (Bank A) - There are 84 of these, every cell is reported
- Individual Cell Voltages (Bank B) - There are 84 of these, every cell is reported
There are two ways to import things into Car Scanner:
1. You can do a "Backup". This stores and retrieves
everything including the PID's and all of the Car Scanner settings including the dashboard setup and everything else. The file format for this is ".cbz".
2. You can also save and restore just your custom PID's. This is where all of our customized Clarity PID's reside. This file format is ".csp", and you save or restore this from the "Sensors" settings page. There is a trash can at the top of the page which can clear all of the custom PID's if you want to start from scratch.
I have attached both of these files to this posting. My suggestion is to use the "Backup" to restore all your settings from my attached ".cbz" file. It has all the Clarity goodies, and settings for a Honda / Acura Hybrid which gives you quite a few more that happen to apply also. If you successfully import a backup from this file you will have ~180 Clarity PID's that will appear on the 'sensors' page.
This includes a simple dashboard that shows some of the key battery stuff. If you develop a better dashboard, please share it with the group.
You can always use the use the "All Sensors" button on the main screen to look at the large list of values (including the Honda Hybrid ones) when connected. The Clarity-specific values are all together at the bottom of the list and are easily identified because the names all start with [Clarity].
