Hi there. Long time lurker but haven't browsed in a while. This is an intriguing topic and got me curious to see what my capacity is. My guess o meter has been netting me 38 to 40 miles of ev range and I think it is because I live on a hill where I don't regen on the way down given I charge to full. I also don't have LRR tires. With that said, I think my capacity should be within expectation but wanted to check.
Before I invest in Vgate device, wanted to see if anyone in the southern California, orange county area wanted to meet up to test my battery and chat it up. Let me know... Just private message me. If not, no worries.
Lastly, BIG THANKS to all those that contributed to the effort.
Shockingly, my car, a 2019 Clarity with 52000 miles has a 53.8 ah battery. I’m still shocked. Was bought by a dealer from CarMax and flipped over to me.
The battery capacity is only reset after a full (100%) charge starting from an SOC (state of charge) of less than 30%). If one has a 50 mile EV range (on the dash meter) after a full charge, a 30% SOC corresponds to about 11 EV miles left. Currently, I recharge our Clarity about five times a week to about an 85% SOC and the SOC rarely gets below 50%. We drive mainly on EV around our small town. We use HV on any trips longer than about 20 miles but such trips are rare (we have a gasoline powered car just for our longer trips, all well over 100 miles a few times a year). Once a year, or so, I let the Clarity battery run down to about a 20% and recharge to 100% SOC to reset the battery capacity. I started doing this just over a year ago with a new Level 2 charger. Before that, I had set the Honda Smart Charge to stop at 85% but at least once a month, Smart Charge would fail and the charge went to 100%.
Over the past 15 months, our battery capacity has went down from 50.06 AH to 49.96 AH. I think this is great. You can see the battery capacity data under user Leop. BTW, we bought the 2018 Clarity Touring in February of 2018. It was the first Clarity our local Indiana Honda dealer got.
You are almost certainly affected by a Battery Capacity Reset.
There is a discussion about this at the bottom of the page here: https://github.com/clarity-phev/Battery-Capacity-Read
Your capacity is probably lower than 53.8 Ah, and it can take many months for the capacity reading to return to 'normal' (depending on charging scenarios). A typical vehicle with ~50K miles will have a capacity more like 46 Ah.
The best thing to do is keep checking the capacity over time in order to look for trends.
I think my comments above about the battery capacity reset can be misinterpreted. I was speaking toward how the Clarity battery management system determines the battery capacity. Just like in laptop computer or cell phone, the battery mangement system measures the charge (coulomb counting) going into and out of the battery. To get the battery capacity (measured in amp-hours where an amp is a coulomb per second), the best way is to start with the battery at zero state of charge and end at 100% SOC. However, it is hard to start at zero battery charge as that hurts Li-Po batteries. But, if one knows the starting SOC, say X%, one can get the battery capacity by just normaizing the measured amp hours by 100%/(100%-X%). For batteries in general, one can estimate the SOC by looking at the open circuit votage. However, Li-Po batteries have a nearly constant OC voltage from 25% to 75% SOC which make it hard to estimate the SOC in that range. This is why one is asked to completely discharge (this gets the battery down to about a 10% SOC) a laptop or cell phone battery before starting a battery capacity measurement. The Clarity BMS works the same way and it is my experince that the Clarity BMS will take about a 30% SOC to enable a battery capacity measurement.
The other meaning of a Clarity battery capacity reset is when the Clarity BMS loses the battery capacity measure. Some say that this can happen when the Clarity has a some sort of a system failure. In that case, the battery capacity may be reset to the new battery capacity of about 55 AH.
I think that many higher than normal battery capacity values may be the result of the Clarity not being fully charged from an SOC of less than 30% for a long time. This can happen if a Clarity is recharged everyday but is not driven very far each day.
Leop
Just like in laptop computer, the battery mangement system measures the charge (coulomb counting) going into and out of the battery. To get the battery capacity (measured in amp-hour
Although this may be true, it is not this simple. We have a lot of examples where someone experienced a 'battery capacity reset' after a visit to the dealer or whatever. These people do not coddle their batteries by intentionally limiting charge depth. In spite of this, the capacity reading does NOT bounce back to normal for very long time. In my opinion, there is some kind of heavy averaging in Honda's algorithm such that it takes many 'full' charges (low to 100% or similar) before the reading slowly returns back to where it should be. You can of course make it take even longer by not allowing the vehicle to have these full charge opportunities, but I think all you are doing it is making the recovery process back to a 'true' reading take even longer.
Of course if you have always coddled your battery from day 1, the normal expected degradation effects inherent in Lithium Ion technology will not be as bad because cycles do magnify degradation. For the most part, people aren't doing this and the curves demonstrate the long recovery time with these reset events.
Just a point of reference regarding an unintentional battery capacity reset.
Yesterday, my 12V battery died (2018).
So, I took the old battery out, went to the Honda Dealer to pick up a new one, came back home and installed the new one.
Altogether, the car had no battery for maybe an hour.
When stating, there was the expected array of failures on the dash and the head unit. These failures cleared up readily upon driving.
In spite of this, this loss of power did not cause a Battery Capacity Reset.
Bottom line - do not worry that replacing your battery will reset your capacity reading. At least not if the battery is out for an hour or-so.
Thanks for that update. I also have disconnected the battery momentarily without causing a Battery Capacity Reset. This makes me continue to wonder what specific variables do cause that reset. I don't recall anyone on this forum specifically pinning that down.
Most things on a car that are expected to degrade (ie the fuel system, battery, engine, etc) are continuously "learning" or "adapting", sometimes only during certain conditions. Typically, this is gradual, and if the computer is seeing something that exceeds what it expects, it will usually enter a contingency, this sometimes is resetting the learning, sometimes it will go to a "base" setting. If I had to guess, this "reset" of capacity is caused either by a failure or accelerated degrading of the cell, that triggers the BCM to reset its capacity learning. The clarity, like almost any modern EV will perform cell balancing, and if a single cell is degraded, automatic functions will attempt to compensate. Probably with that is it isn't perfect, and one cell can drag down the entire pack depending on how degraded the cell is.
We are ready to offer additional PID's that provide quite a lot more functionality.
Since Torque has the substantial problem discussed above, these new PID's are packaged for use with Car Scanner.
** Important ** We had to get the Car Scanner developer to tweak the import / export functionality to enable this to work completely. He has a public beta for this on the Google Play store, and you will first need to update your Car Scanner to that version (Currently version 1.75.9). I presume he will release this once validated. You can google to learn how to access a public beta version... Not clear how long before he will release this officially, but hopefully we will know when he does.
** One Other Note ** - Somewhere along the way with adding all this functionality, Car Scanner advised me that I had exceeded some limit of the free version and I had to upgrade to Pro. I don't know exactly what triggered this, but It was only $3.99 and the developer has been very cooperative with us. I submit to you that it is well worth it to have all this functionality for your vehicle ! So, you can try the free and see if it works for a while or just upgrade from the start.
This functionality includes the following:
  • Battery Capacity (Total)
  • Battery Capacity (Just Bank B)
  • Individual Cell Min SOC (Line A)
  • Individual Cell Max SOC (Line A)
  • Individual Cell Min SOC (Line B)
  • Individual Cell Max SOC (Line B)
  • Overall SOC
  • Air Temperature Inside Vehicle
  • Air Temperature Outside Vehicle
  • Transmission Temperature
  • Individual Cell Voltages (Bank A) - There are 84 of these, every cell is reported
  • Individual Cell Voltages (Bank B) - There are 84 of these, every cell is reported
There are two ways to import things into Car Scanner:
1. You can do a "Backup". This stores and retrieves everything including the PID's and all of the Car Scanner settings including the dashboard setup and everything else. The file format for this is ".cbz".
2. You can also save and restore just your custom PID's. This is where all of our customized Clarity PID's reside. This file format is ".csp", and you save or restore this from the "Sensors" settings page. There is a trash can at the top of the page which can clear all of the custom PID's if you want to start from scratch.
I have attached both of these files to this posting. My suggestion is to use the "Backup" to restore all your settings from my attached ".cbz" file. It has all the Clarity goodies, and settings for a Honda / Acura Hybrid which gives you quite a few more that happen to apply also. If you successfully import a backup from this file you will have ~180 Clarity PID's that will appear on the 'sensors' page.
This includes a simple dashboard that shows some of the key battery stuff. If you develop a better dashboard, please share it with the group.
You can always use the use the "All Sensors" button on the main screen to look at the large list of values (including the Honda Hybrid ones) when connected. The Clarity-specific values are all together at the bottom of the list and are easily identified because the names all start with [Clarity].
Tried this amazing tool today and loading the backup file loaded 3 dashboard panels of mostly empty stuff. Might have done it wrong but restored my backup and that worked well again. Made a few screens myself but definitely wanted to look at your handiwork.
It has been quite a while since I did anything with dashboards. Perhaps enough things have changed with Car Scanner to break the earlier dashboards but I don't know. I have been content to just look at the parameters of interest from the long list, but I have also mostly abandoned the Car Scanner App in favor of the ELM 327 PC-based Approach described in Github page:
The PC approach is not good for live monitoring of dynamic parameters, but it is good for archiving battery parametric data over the long term by saving the reports that it generates.
Totally get that. I haven’t been able to make it work with my Mac yet because I think my vGate has given up the ghost, possibly by being connected to a faulty 3way connector. on the new one I'll disable the deep sleep and wrap a light electrical tape around it I guess to keep it better connected.
Has anyone tried it with a Mac yet? FWIW, I think these will be the Mac instructions I will try when the new vgate comes in tomorrow. will edit this post to confirm when I try it. posting here for others following.
  1. Open Terminal
  2. If Homebrew isn't installed, install it first:
    /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
  3. Once Homebrew is installed, run:
    brew install blueutil
  4. Wait for the installation to complete
  5. Use system_profiler SPBluetoothDataType to list Bluetooth devices
  6. Use blueutil --pair [MAC_ADDRESS] to pair
  7. Use blueutil --connect [MAC_ADDRESS] to connect
To disconnect:
  • Use blueutil --disconnect [MAC_ADDRESS] in Terminal
  • Or click "Disconnect" in Bluetooth preferences
Thanks for pursuing and documenting your endeavors with the MAC !
If you get it working, I will update the information on the GitHub pages to include specific MAC instructions.
I have used it with Windows and Linux (using Chrome in both cases). I have a vague memory of trying Firefox and having a problem, but details escape me. The next time I run it I will try Firefox again to clarify.
Ha! Well I'm not able to edit the old post - but the Mac Instructions are the easiest of them all. Disregard anything in Terminal.
1. Connect to the device in System Settings > Bluetooth like a normal device
2. the vGate iCar Pro BLE 4.0 for iOS/Android's Bluetooth is 1234 (very important, 0000 for others perhaps)
3. Must use Chrome, go to https://clarity-phev.github.io/powertrain_report/
4. Connect to the device, Load Data, Generate Report.
Congratulations on a really incredible platform you've built. Wish some of the github pages had better links and html instead of pdfs. there's one PDF that's just a link to a different page of a HOWTO that's moved that I wish were just a little easier to use. But those are mere dumb complaints to the major credit you deserve for building it.
Great news, congrats again on what you've built. I won't pollute your data on the official charts with what I have for now which feels ambitious. Still showing
HV Battery Capacity (A+B): 54.10ah
HV Battery Capacity A: 27.05ah
HV Battery Capacity B: 27.05ah
But I guess I might get news in the next 1000 miles? We'll see.
Odometer: 57380 mi.
Distance traveled since Battery Connected: 2179 mi.
Distance since DTC Cleared: 2187 mi.
Feels like I was clearing the DTC just a few days ago...
Thanks again for what you built for us. Saved me a couple hundred on a transmission oil change I was considering making at 60k until seeing this data. I do need to dive into the infotainment without CarPlay sometime again soon, but great to see it all out here.
Time will tell, but I am fairly confident that your vehicle has experienced the Battery Capacity Reset. This is described on the GitHub page. I think your numbers are too good to be true for a vehicle with almost 60K miles. What is the history of your vehicle? Keep an eye on your capacity reading (I was checking mine every few months when we were using the Clarity regularly). The capacity will slowly (sometimes very slowly) return to 'normal' which should be more like 47 ah for it's age.
Your battery was 'disconnected' 2179 miles ago. Was that when you bought it? Was there some dealer action at that time that could have reset the capacity?
I just got a maintenance minder notice that it is time to change my transmission fluid (2018 with 43K miles), but I think the transmission oil (and the brake fluid) are triggered more by time than by miles (6 years, and 3 years respectively).
I do realize that this reply is off-topic, too.
The brake fluid change is definitely by time. Brake fluid absorbs water even through the capped reservoir and hose lines. The Clarity brake system is too complex to consider not changing out the brake fluid every three years. I use a vacuum extraction system to do this twice, once with the Clarity in run mode and once with the Clarity turned off. The only time consuming aspect is getting all four wheels off the ground so the wheels can be removed.
The transmission fluid also appears to be by time, too, at least in most cases. Lubricating oils also affected by time as well has by heat. The Clarity transmission fluid lubricates the wet engine drive clutch and the reduction gears. Again, the Clarity (and other Honda hybrids) have a complex system. Changing out the transmission fluid every six years is not an expensive proposition especially for the average do it yourselfer.
LeoP
The manual is a bit cryptic on transmission fluid change; indicating it is driven by maintenance minder code 3, with no info as to what triggers that. However, it does have a note suggesting if you spend a lot of driving time in mountainous regions at low speed, higher xmsn temperatures abound and you should see to a change at 47,500 miles / 3 years. Dealer located records indicating mine was changed at 86k, about 10k prior to my purchase and I acceded to their recommendation to effect a subsequent change at 123k. Sounds like they took me for a "mountain man."
