Are there other apps besides Car Scanner that can read the battery data?
The problem is that the Clarity uses a longer message length. This causes two problems - First, many OBD adapters fail, and Second, even with a 'good' adapter, many Apps fail. We tried one of the most popular ones (Torque, or Torque Pro) and it could
NOT handle the longer messages that the Clarity uses. We found that Car Scanner worked (AND the developer was very responsive and incorporated our Clarity PID's into his App).
What is your objective? We have identified 3 known good ways to obtain the Electric Powertrain data. First, Autel, with the AP200 and the Honda Beta Code that we can obtain authorization for. Second, a 'good' ELM327 OBD II adapter (known good is the Vgate iCar) with Car Scanner. Third, the same known good adapter used with a custom program to read data directly to a PC and generate reports.
Is there some reason that none of these appeal to you? If so, please elaborate as to why. In theory, with a good ELM327 adapter, any App could read the data, but you (or the App developer) would need the PID's that we have identified, and they would need to support longer messages than what is typical.
