Battery replacements are starting
  • Thread starter Thread starter gonfunko
  • Replies Replies 185
  • Views Views 28K
For the record, I just had my 2019 Kona EV's battery replaced today (July 14, 2021). I was told the battery was an upgrade, but did not tell me what that really meant (i.e., more miles/charge, etc.). The process was took about 5 hours to complete. I will keep you posted should I discover any surprises (good or bad) with this new battery.
And I've got my car back! Picked it up this morning (dealer called yesterday to say they'd need a bit longer). They were nice enough to wash it and charge it up fully, to 332 miles on the GOM, so it seems this didn't involve a GOM data reset. I've attached pics of the old and new battery stickers and the work order FWIW.
View attachment 12716 View attachment 12717 View attachment 12718 View attachment 12720
Great to hear it worked out for you.
I see they changed the bolts as well, thanks for the picture of the invoice showing the part #s. I wonder if the 3- 00282-19091 are quarts of coolant added, any idea (is your coolant green?)
Have you checked the coolant level in the reservoir? It might pay to mark it with a felt, just in case it lowers (they might have just topped it up with the flow valves closed) when the cooling system initiates on the next DC Charge, just a thought.
2nd post today for replacement, things are looking up. Happy to hear the cards are finally falling into place. I hope that will be the end of the issue for you and the pack outlasts the car (as it should).:)
Coolant is blue (assuming it's the one behind the 12V), filled to maybe half a centimeter above the max fill line, and there appears to be a little residue on the outside/the cap has a wrench mark, so I assume they did top it off. I'll double check it whenever I fast charge, thanks for the suggestion!
Looking up in the U.S. maybe. Still just rumours North of the border as far as I can tell.
It's rather impressive that Hyundai has got to this point considering the huge number of batteries they have committed to replace. It's only eight months and they are sourcing the batteries, getting them shipped across the ocean and through the congested ports. Then they have to get to the dealers who would not have been expecting the workload and seem to be in differing states of readiness. They've been getting the bricked vehicles back running first. While my car was bricked I was thinking through the steps it would take to get a battery to the car and installed, and even though it took several months I was pleasantly surprised it was such a short time. From some of the comments here it's clear that in some places owners are not receiving the information they expect, and this has created uncertainty, but as electriceddy says the cards are falling into place.
Were people here contacted by their dealership or did you initiate the request? After the previous recalls, my dealer said they will contact me. I was going to try buyback initially but Hyundai never got back to me about my case. With multiple requests/calls.
I contacted my dealer after reading comments in this thread about others doing the same and getting things moving.
This makes Hyundai look good with their decision to replace batteries.
https://www.cnbc.com/2021/07/14/gm-...side-or-charge-them-unattended-overnight.html
https://www.nhtsa.gov/press-releases/consumer-alert-important-chevrolet-bolt-recall-fire-risk
GM's decision to rely on just a software update to stop the fires is not working out too well.
1. True, but let's not forget that Hyundai also tried (and is still trying) to make a software fix work.
2. Saying you will replace batteries and actually doing it are very different things.
I'm not prepared to dole out my limited supply of goodwill to them yet.
From how I understand it, all dealers need to perform a traction battery check (several hours), and crossmatch your battery to Hyundai's database to determine if you have an affected battery.
In some cases, another software update has been applied to some cars.
If you don't trust your dealer, you can try taking it to another dealer to get a second opinion....not sure if that can be done once the first dealer closes your recall. You need to call to ask.
Sorry for the crosspost but I don't know if everyone follows all threads. Yesterday I took my 2019 Kona SEL to the dealer for recall 200 and was told I don't need a new battery. They changed the max charge to 100%. I'm in the US.
I got the same results. They checked the label on the battery and determined it was not necessary to be replaced. Recall was closed out. Max charge 100% back again.
Yesterday, I took my 2019 Ultima to the dealer. They checked the battery and determined I need a new battery and ordered it. I was told it may take several weeks to receive the battery. The car has 6000 miles on it. Max charge remains at 80% for now.
While there, I checked on when they expected more info on the 22 Iconiq 5. They said they did not expect it until winter ?
New Jersey
Must be something in the UPC labels identifying the cell(s) manufacture/assembly date and location if from the same Chinese production line.
I sure would like to see a label picture of both yours and Tracy's and Jolee's pack. When posting the pictures, please add the footnote - R/C 200 good pack, or R/C 200 needs replacement Perhaps some bar run is common between the 3 UPCs that would give a good basis of determining that. There are UPC decoders out there, even if you wind up with a bunch of numbers that don't make much sense, someone may be able to piece it together. If we also had a couple of pictures of pack labels that do require replacement (pending after R/C 200) that would help as well;)
I also posted on the Niro EV forum if some label pictures could be posted, (to compare the SK innovation UPC codes as well but no one has offered - yet)
I am sure the replacements will be LG, but it would be nice to have Kia labels just to see if SK Innovation cells are involved with the actual replacements.
Long shot...you bet, but what else do we have to work with other than the tight lipped communication Hyundai Corp and it's dealers are providing owners.
Good battery label, passed inspection by dealer. Recall 200 is closed out.
https://insideevsforum.com/community/index.php?attachments/battery-label_100840-jpg.12466/
The same thing happened to me. In Northern New Jersey, 2019 SEL.
I got my battery replacement done yesterday. The whole process went smoothly, as far as I could tell. The dealer got me a loaner, but they finished in about 6 hours. They said it was their first time doing the battery replacement. New battery charged to 100% overnight, indicated 266 miles of range.
I'll attach photos of the old and new battery labels. For some reason there were no identifying numbers on my old battery label. Maybe lost in two Vermont winters? I did find what looked like a serial number stamped on the old battery.VIN_plate.webp old_battery_stamp.webp old_battery_label.webp new_battery_label.webp
I'll attach photos of the old and new battery labels. For some reason there were no identifying numbers on my old battery label. Maybe lost in two Vermont winters? I did find what looked like a serial number stamped on the old battery.View attachment 12892 View attachment 12891 View attachment 12890 View attachment 12889
So it's July 27th and the battery was manufactured on March 10th. Seems like Hyundai is in no rush. Like we didn't know that already.
