Viking79, could you post the link to the online parts catalogue for those of us too lazy to search for it? ThanksLooking at online parts catalogs, both Clarity EV and PHEV appear to have same heater (heat pump). This is good, and explains why the Clarity heater is so much better than my Volt in the 10 to 50 F range, and seems to use less power. Surprised they don't advertise this.
Guess I will start a new thread on the winter driving stuff and leave it to you to chat about the heating thing.Dear prestoOne, don’t know the source of that quote but it seems to say the battery and inverter are all on the same coolant loop. If you look in the manual and look under the hood, there are three separate coolant tanks.
On page 482 of the manual it points out locations and describes them as:
1. Inverter coolant expansion tank
2. High voltage battery system coolant expansion tank
3. Engine coolant reserve tank
Manual goes on to show checking of levels and leaks in each. Where did you find the quote that says the first two are all one system? Or am I just reading the manual wrong?
OMGNo prob. But where is the quote from?
It would help us understand the system better.
It was from a Car&Driver article.No prob. But where is the quote from?
Lots of problems with that Car and Driver article. Go to the end and read the comments on it.It was from a Car&Driver article.
It will work, but your EV range will take a huge nosedive. That resistance heater absolutely sucks electrons out of our battery like there’s no tomorrow!After being overwhelmingly unimpressed with the pre-conditioning through the sub-zero winter temps, I installed my Level 2 charger and have the pre-conditoining start at 7 AM. Nowadays, the car is fantastically toasty warm when I get in at about 7:30. It works great with the Level 2 charging unit I have at home. Still not sure if it works well in sub-zero temps when not connected to a charger.
