  • Replies Replies 1K
  • Views Views 218K
I just checked my snow tires, and two of them have really good depth, one is pretty worn, and the last one is very worn plus unsafely bald on the outer edge. Looks like I only need two new snow tires this season, so that's pretty good news. I've never driven on two styles at the same time, but it should be good right? My current snow tires are Nokian Hakkapeliitta R3s, the ones available now are R5s. So a newer version of what I have. The comparison review says the R3s are better on snow, but the R5s are better on ice. So maybe I'd get a nice balance of handling.
Unfortunately the Hakkapeliitta R5 EV tire is 18" or bigger, so no go on the SE.
Nokian Hakkapeliitta R5 Vs R3
I and a few other here have the R5 (non EV). In 195/55/R16 XL they are amazing on economy and noise, almost not like winter tire. I am getting 4.7-5.3mi/kwh right now (no cabin heat yet, 35-55F) in suburban commuting, with the Spectre Gray ultra light rims (15lbs). Last season with heavier rims (20lbs) I did 4.3mi/kwh average for the entire season, with more highway commute than I do now.
While perusing tire sites, I came across some new Goodyear Eagle offerings, in sizes that fit the SE.
Eagle® F1 All Season
Eagle® F1 Asymmetric 6
I've been driving on Eagle F1 Asymmetric 3s and I'll need to get new summer tires come spring so now I have to decide if I want to try one of these new ones. Apparently the Asymmetric 6 is really low rolling resistance making it "EV ready." I sure wish the US would adopt the EU tire ratings.
And here's an interesting tire test that seems to cover most of the tires we use on our SEs.
2025 Al Volante Summer Tyre Test
Asymmetric 6 8.7kg/t is class C Euro rolling resistance. It's probably nearly double that of the stock SE tyres. I'd rather use Yoko V701 with that much rolling resistance.
It's extremely hard to find truly low rolling resistance tyres in SE sizes in the USA. There is no US standard for 'low rolling resistance', so tyre manufacturers can and do call any tyre 'low rolling resistance'. Not a single one that I have asked for actual figures will reveal them. I have a set of Conti ECS02 'low rolling resistance' tyres that have higher rolling resistance than Yokohama A052...
Found the EU label for the Eagle F1 Asymmetric 6, definitely not great for rolling resistance. I think I'll stay with the Asymmetric 3 as long as I can.
Eagle F1 Asymmetric 6:
Compare to the Eagle F1 Asymmetric 3:
Your labels are comparing different widths tires, which is not apples to apples. In 205 that likely going to be a B rating. Still, probably worse, but not as bad as C/you think.
That's unfortunately the fault of Goodyear's site, it says 205/45R17 at the top of the web page.
Edit: found the correct label on the page, same ratings except A rating for noise, like the Asymmetric 3.
right, I would trust the picture/label more than what the site says. Probably someone uploaded the wrong label or they don't have one for the 205. You can see if you can find label in 225 for the older tire to make apples to apples comparison.
I have been putting it off a long time, but today I called and ordered four new summer tires for my F56 SE. The OE Goodyear Eagle F1 Asym 3s are practically bald after about 27,000 km (16,700 miles) over the course of four summers. Decided to spend a little more money for tires that have a reputation of lasting a lot longer: Michelin Pilot Sport 5. Installed and balanced for $340 Canadian plus tax each. The OE tire was available for $280 plus tax each. So I'm spending about 22% more, but I fully expect Michelins to last at least 40% longer, and perform better in general.
Very interested to hear how they work out for you - I'm probably going to need to replace my summers very soon, too.
That's what I'm thinking. I do about 6000 miles a year, so let's say 4000 on the summers (early-April to mid-November, generally). Even a 10% hit doesn't equal the 40% quicker wear on a US$1000 (plus tax) set of tires. And if they actually drive better? Win-win.
When I switched to 300 tread wear tires from the OEM 'kooks, my efficiency dropped about 10%. For me, it's worth it.
I had such a bad range hit from Conti ECS02 that I changed my mind about using them dailies. About 20%. Instead, they are purely my autocross 'full wets'. Something they are very good at. My winter tyres are Nokian WR-G4 all weathers. Range hit on those is hard to measure, I highly recommend them. I'm currently looking for some new summer dailies. My local Mini dealer appears to have stopped selling my size, so I'm casting my net further. Range is important to me, I do enough longish trips that I really don't want to lose any. It's silly when I drive 100miles on my dailies and have ecs02 in the back, along with another set of wheels and tyres...
