Service for Kona
  • Thread starter Thread starter Ev050
  • Replies Replies 72
  • Views Views 25K
Fram cabin Air filter #CA12057 made for Kona EV 2020 from Car Parts Discount cost $9.95!!!!!! Also Auto Zone sale for $18.00
Janusz the filter # you quoted is a Fram engine filter for a Kona ICE vehicle, it clearly won't work as a cabin filter. Fram does not have a cabin filter listed for a Kona EV. They have a cabin filter for the ICE version CF12160 but be aware it will not fit. FYI, the correctly sized Elantra cabin filter is available on Rock Auto for $5.77. The number for the Fram equivalent is CF12058, unfortunately it is not available on the Walmart site.
The Elantra filter is available on R
Janusz the filter # you quoted is are FRAM engine filter for a Kona ICE vehicle, it clearly won't work as a cabin filter. Fram does not have a cabin filter listed for a Kona EV. They have a cabin filter for the ICE version CF12160 but be aware it will not fit. FYI, the correctly sized Elantra cabin filter is available on Rock Auto for $5.77
I will double check I did replaced in 2020 EV kona from auto zone I will be posting new number!
Just be careful with the Amazon and Ebay listings that claim that they fit the EV often they are generic ads and the seller assumes if they fit the ICE Kona they fit the EV. In the posted link even though it says in the title its for Kona EV if you look in the description for fitment lower on the page it says it fits the 1.6 and 2 liter Konas so it likely does not fit the EV. The ICE filters are almost 2 inches longer .
I have never had a single problem buying auto parts from Amazon, so long as I use the filter at the top of the screen for the parts.
It was time to put my winter tires on today and I decided I was going to do my service #2 myself which also included changing my $5 cabin filter and inspecting the brakes and re-lubing the brake caliper bolts. As expected at 17,000km and 11 months the brakes and slide bolts looked pretty much perfect. There was virtually no pad wear on both sets. I am honestly not sure why Hyundai specifies a brake service at year 2. If your going to do this just be careful with the electronic rear parking brakes, unless you have a bidirectional scan tool that can put the car in brake service mode don't turn on the car or try engage the brakes with rear calipers off, otherwise you are going to have some trouble getting the caliper assembly back on. The two flange bolts that secure the sliding caliper pins are pretty east to loosen( only around 20 ft pounds),
the brake slide pins are then easily accessed when you swing the caliper out of the way.
You don' t have to remove the caliper assembly completely if you like. Use a silicone based grease meant for brake lubrication.
As you can see there is tons of brake pad material, next wheel swap in the spring I will take the pads out and make sure they are not glazed or delaminating from the obvious infrequent use.
... I am honestly not sure why Hyundai specifies a brake service at year 2...
That got me thinking since I'm just about to go in for my year 2 service. I checked both the EU schedule that I guess we're using in NZ, and the US schedule and they only specify the same brake "inspection" indicated for every year. Just Canada perhaps?
Its probably a Canadian thing based on their online severe usage service menu. Hyundai unfortunately considers all of Canada falling under severe usage. Anyways this is the cut and past of Service #3 from their website as to what they expect of us at 2 years or 48,000 Km. I am still trying to find the clutch and its appropriate fluid so I can adjust them, lol :)
Service #3 includes:
  • Tire rotation
  • Check battery condition and terminals
  • Check 12V battery condition
  • Check fluid level (coolant and washer)
  • Service front and rear brakes
  • Inspect cooling system hoses and connections
  • Inspect exterior lights
  • Inspect tire pressure
  • Inspect and lubricate all latches, hinges and locks
  • Inspect driveshafts and boots
  • Inspect suspension mounting bolts
  • Inspect steering gear box, linkages and boots/ball joints
  • Inspect brake lines, hoses and connections
  • Inspect air conditioning refrigerant for any leaks
  • Inspect air conditioning compressor function
  • Inspect brake/clutch (if equipped) fluid
  • Inspect clutch(if equipped) and brake pedal free play
View attachment 7528 5k service is just tire rotation.. You can do this yourself. Only thing requiring changing before 120k miles is Cabin Air Filter every 15k miles. All other maintenance items are "check" items only like brakes, fluids, suspension parts. I do that myself. I'll probably even flush the coolant at 120k mile myself.. Not going to pay the dealer $200 for something that I can do myself..
If you have the blue coolant, you might not be able to do that yourself, as my understanding is that special equipment is needed and getting your hands on the correct coolant could be tricky.
Excellent photos, great to see minimal wear on the entire assembly. Additionally you have video documentation of the service performed correctly.
Thanks for that and will bookmark this post for future reference:)
Just to clarify in the Canadian 2019 owner's manual (and possible on later model year revisions), maintenance section footnote describes "I" (inspection) as
"I : Inspect ( inspect and if necessary , adjust, correct, clean, or replace)"
One of the few sections that are close to being specific.
Funny they don't include lubricate :rolleyes:
I will document my 45k mile / 72k km inspection also with pictures.. That's a good thing to do... I'm almost at 38k miles, so 7k miles until 45k miles.. Considering that I'm only driving 2k miles per month due to COVID19, this will be early next year..
I am still confused, my 2019 has blue coolant, so are you saying mine isn't the expensive one though? That would be awesome.
Just realized that I passed 37500 miles on my 2019 and Gear Reduction Fluid check is due.. Does anyone know how to check gear reduction fluid?? I searched youtube but didn't find any indication how to check it..
My reading of the partsgeek description is that this is ENGINE coolent!
That's probably because it's not specifically made for electric vehicles.. I believe that the earlier Konas with the green coolant use the same coolant as used with internal combustion engine motors.. So, the coolant likely is an engine coolant but that's what I believe that they used in the Kona Electric.
