R P
Yes, if you didn't adjust your L2 charge current on the car. But you can adjust that lower, so you draw less power.Wouldn't the 32 amp version trip the breaker on a 30 amp rated outlet?
True.. Didn't think of that..Yes, if you didn't adjust your L2 charge current on the car. But you can adjust that lower, so you draw less power.
I would like to test the 3 L2 charge rate reductions on that screen to see the actual current with my RMS clamp on meter , some other time I will post.However, just remember that 3000 watts is only 25 amps at 120V (80% of breaker). That's what Fastnf said he was drawing at the max setting for L2, post #7. So sounds like you can leave it on the max setting, same as 240V which will of course then draw higher kVs.
Since you can't establish continuity because of the relay, how exactly did you confirm which 14-50 hot prong (X or Y) to connect the RV neutral? I would assume Ln2 on your EVSE would be the same as on mine to conform to the EV J-1772 standard.Yes that is correct. The 14-50 neutral is empty not the L2/N. The neutral on the TT-30 (Travel trailer 30 amp plug)( white wire) goes to one of the hot leads on the 14-50, the black hot goes to the other hot lead. That way instead of seeing 240volts across the two hots you see 120 volts across the two hots. The neutral must show continuity from the TT-30 through a hot lead on the 14-50 ending up at L2/N on the J-1772 Here is a picture of my j-1772 plug showing L2.
You can't do a line test to L2 because it goes through a relay that is open when the car is not plugged in, and obviously you cant do a line test when its plugged in an powered up.
Thanks, the additional pics and explanation are very helpful. But I don't understand you saying the neutral could work on either x or y. Does that position not correspond directly to the L2/N prong on the J-1772?I could have put either x or y on line 2 and it wouldn't have mattered. Even now I could switch line x and y and make the same switch in the 14-50 adapter plug end and it would work. So it doesn't matter if line x is neutral or line y is neutral as long as the chosen line for neutral connect to the line for L2/N prong on the J-1772. ]
What make/model EVSE do you want to try this with?Thanks, and sorry for being a little dense. But I learned a lot...
So getting back to the Tesla RV adapter. If I try it, and my EVSE happens to have the L2/N on the wrong 14-50 prong, will it just not work, or could there be damage to my EVSE or car?
I may try it with my Morec, which appears to be identical to the SimplyWork one. Mine does not specify 110V compatibility, but it does say it has low voltage protection. The SimplyWork EVSE says it works for both 110 and 240.What make/model EVSE do you want to try this with?
Looks like it may work but who knows the schematic - why not just email Morec (c/w model #)and ask first?I may try it with my Morec, which appears to be identical to the SimplyWork one. Mine does not specify 110V compatibility, but it does say it has low voltage protection. The SimplyWork EVSE says it works for both 110 and 240.
https://www.amazon.ca/Morec-Upgrade...A8XF6JWAPVC&psc=1&refRID=1A7QNG321A8XF6JWAPVC
https://www.amazon.ca/Charger-110V-...ncoding=UTF8&refRID=GN5SNE6QE136FF87CSRX&th=1
I did actually send him an email, but got no reply. I also spoke to the SimplyWork guy and he says his works at 110V and 12A (same as the granny cable) with an adapter, but didn't know anything about the 30A RV adapters and being able to charge at higher kVs. Seems like these guys just sell them and don't know much else about the specs or schematics. And the little instruction book that comes in the box tells you nothing. Doesn't even name the brand, looks more like a generic booklet that could apply to many EVSEs.Looks like it may work but who knows the schematic - why not just email Morec (c/w model #)and ask first?
