Fastnf
One ot
Another option would to put a NEMA 6-20 volt plug (240 volt 20 amp ) in your garage then get a 16 amp EVSE with a NEMA 6-20 plug and then get a 14-50p to 6-20r adapter for the work plug. This would allow you quicker charging both at home and at work.
Here example links below.
https://www.amazon.com/Beswelgo-Portable-Charger-Electric-Charging/dp/B08HSDPJ8N/ref=sr_1_16?dchild=1&keywords=16+amp+evse+14-50&qid=1614528547&sr=8-16&th=1
https://www.amazon.com/NA-XUANHUA-W...cphy=9013163&hvtargid=pla-1123944615355&psc=1
Thank you KiwiMe and Fastnf for the swift responses. Most appreciated.
It's good to be reassured that the granny cable will limit the current flow. I do understand that using the 240V adapter will put the EVSE at risk. We have two as it happens because I have a Prius Prime and have used that one to charge the Kona also but at 120V.
The Beswelgo portable looks interesting as it would solve the problem nicely, but then, knowing me, I'd want to use it at home and although I have a distribution panel in my garage it's wired as two 20A circuits from the main panel and so won't accommodate a 50A breaker to run the 14-50.
We could go with the low cost option and just buy the adapter (thank you for that link too) and I suspect that will be the final solution since my wife has free high speed charging at her regular job and I can get by most days on 26 or so miles I can get from an overnight charge for the Prius.
Thanks again for knowledgeable the help.
