electriceddy
Moderator
Click on the underlined "Watch on You Tube"Hm ... video removed
I will definitely ask for an inspection on the mechanics recommended "Canadian cycle" @ 24K kms ( '21 Canadian Hyundai manual is 28 months - 56K kms cycle) for inspection and the results are obvious.Got it!
I find this concerning. What kind of material are the gears made of? What kind of oil does Hyundai use here. Today's lubricants (particularly synthetics) tend to last for ages/miles/kilometres - take your pick.
I had the 'transmission' fluid checked in our Mitsubishi iMiEV at 40,000km by the dealer - it still looked 'used but clean'. Nowhere near black.
It means dropping the under cover and opening the fill plug, so unless it is crystal clear I will ask it to be changed as the cost at that point is minimal. I expect ~ $150, also provide a good opportunity for the mechanics to inspect parts that would not normally be available to observe with the covers on .
This equates to every 3 years at my present yearly mileage accumulation, $50 bucks a year cost. I can live with that.
Doesn't even come close to what I have enjoyed saving with free public charging for the last 9+ years![]()
Sorry, no "dipstick" on our cars, but sure would have made things a lot easierI can't believe that you have to take the car apart to check the colour of the transmission oil and replace it if needed.
But as you say $50/year is not too much.
Sorry, no "dipstick" on our cars, but sure would have made things a lot easier![]()
Air contains 79% nitrogen.Yes, this is a good way to go.I have actually been doing what @Jared Potter has been doing,40psi.I use nitrogen,and there's a difference in inflation retention. flipthefleet seems to feel 3 - 4psi isn't a problem,especially if you're carrying more.
This from a Leaf, I wonder if Kona EV has the same magnetic trap on the drain plug:Got it!
Looking for help!!
My 2020 kona electric 39kw has been in the garage for 6 weeks now. They are saying they cant find a fault.
The AA ROADSIDE ASSISTANCE have had to fix it at the road side twice since i bought it. With a 'check ev system' warning light that also tenders the car immobile.
Error codes 1AA600 AND P0C17 PRESENT
These apparently were wiped when the AA SERVICE reset the vehicle.
Has anyone had any similar issues with their kona ev.
I understand they cant fix what isn't showing but I have given them photos of the codes and diagnostic machine from AA.
IM BASED IN UK but have only seen issues fro. USA and Canada in regards to the codes.
They want me to take back my car and if/when it happens again dont get it fixed by AA Get it recovered and brought to them. But they've acknowledged that its faulty. As have the AA.
HELP!
This happened to my Kona after changing to 100% at home with level 2 charger. Each time I was able to connect OBD2 tester and "clear" the error codes. It says it failed to clear the codes but the car is drivable again. I am in USA.Looking for help!!
HELP!
I posted this in a another thread but I think this thread is more appropriate as I will call this a final resolution to my driveline chatter noise(card in the bike spoke wheels tick). Again to recap the ticking noise started ay 7,000 km, would get more pronounced in the cold. After much hubbub my dealer replaced the traction motor at 17,000 km which resolved the noise until it came back at 40,000 km. The dealer apparently referenced a newly available TSB that directed them to install an updated motor mount kit with new mounting bolts for the engine/reduction gearbox. Finally at 51,000km my car is silent and I like my car againThe trouble is getting your dealer to do things you feel may be best practice but he does not or the direction they get from Hyundai is inconsistent. I first heard the ticking noise at 7,000 Km but it was like pulling teeth to get dealer to do something. They finally replaced only my motor at 17,000km, now at 40,000km I am pretty sure I am hearing a faint ticking under certain conditions. I have learned the hard way just to ignore it and wait for it to get worse because that is exactly what my dealer will tell me![]()
After mulling this over for a few days I'm going to step up and say that I believe Hyundai engineering were remiss in not equipping the Kona gear reducer with a magnetic drain plug. The oil I pulled out of my Kona after 19,000 km was as dark as black coffee and contained a light loading of fine ferrous wear particles.Generally, splash lubricated manual or differentials and pump-lubed automatic gearboxes use one or two magnets to sequester ferrous wear particles. ...
