ClarityBill
There are a couple things that will make the gas engine run, even though you are in Electric mode. Have you noticed when the gas engine is running?Thanks for the link and did open a case..
I bought clarify plug in considering my driving which is 20 miles each way and i charge it at work but instead of using battery it is using gas 30% of the time despite of battery is fully charged...
New to the clarity so any information would help..
Accelerating too fast (past the detente in the gas pedal, if you notice it), will kick on the gas engine for extra power.
Decelerating too fast (especially with a fully charged battery), will activate the gas engine.
Once the gas engine is running, it will continue to run until it has warmed up. This warmup could use 30% of the mileage on a 20 mile trip.
The Clarity starts in electric mode, be sure you are not pressing the HV button: That would put it in Hybrid mode, and cause it to use the gas engine.
Also, staying away from Sport mode will make it harder to activate the gas engine. I generally run in Econ mode.
