Some fair criticisms here, though I'd say at least a couple of us are somewhat familiar with Subaru. I drove a '78 Subaru GL Wagon a fair amount back in the day (which I absolutely loved), and also had first-hand experience with models from the 80's. 90's, and early 2000's. I'm sure Kyle, at least, has experienced more recent models.I watched #84, mostly to see their comments about the Solterra. A little disappointed in their shallow review. Obviously not very familiar with Subaru, and what their cars are all about. If they would have watched the Japanese vid they would have seen it off-road and going up some pretty steep and rough trails. And didn't even mention the clearance, which is so important. Hopefully after this Wed's NA reveal, we will get some better info. Subaru ICE SUVs have superior suspension and AWD traction to handle rough roads and wash board (much smoother than a truck or Jeep). I expect the Solterra to be the same or better.
They also questioned the FWD version projected range, but failed to understand/mention that FWD is more efficient. That is why the Kona achieves such good range, despite not having the best aerodynamics.
One of your own, Kyle, did a recent ID.4 off-road test, and it failed miserably.Some fair criticisms here, though I'd say at least a couple of us are somewhat familiar with Subaru. I drove a '78 Subaru GL Wagon a fair amount back in the day (which I absolutely loved), and also had first-hand experience with models from the 80's. 90's, and early 2000's. I'm sure Kyle, at least, has experienced more recent models.
That said, I should have mentioned ground clearance -- a decent 210 mm (8.27 inches). And, I didn't see watch the Japanese video, which we didn't have in our post and was also not linked to on the Subaru Global media site, either the English side (which also didn't have press photos), or the Japanese side. Am definitely checking it out now.
Regarding the range, I'm quite confident the real world range given for FWD Solterra as 329 miles is very optimistic. The VW ID.4 is a decent comparison vehicle and while it's ~100 pounds lighter, it has a bigger battery and gets a 260 mile EPA range rating. The WLTP is more optimistic than EPA generally. The Solterra also uses synchronous permanent magnet motors on both axles, and so need to always be energized (unless there is a physical decoupling), which is less efficient than the ID.4 which uses an asynchronous induction motor that can simply not receive energy unless needed, which is more efficient.
Like I said, I'll be with Toyota early this week, so hopefully can learn more about it.
He seemed surprised, but maybe he will learn what Subaru owners know that not all AWD vehicles are the same. What is even less known is how smooth Subaru vehicles are over rough roads and washboard. This is a combination of having a long range suspension (soft on top) and permanent all AWD (not slip and grip as used by most others) which just glides over the small bumps and pot holes.
I know this well, because I have a Crosstrek that we use to go to our off-road cabin. The last 15 kms of this road are very rough. I used to own a 4WD truck, that would bounce and rattle your teeth over this same road. The Crosstrek turned what used to be a tense ride into a scenic, pleasant adventure. And we have friends with Jeeps and other SUVs that come up to our cabin, too, and then we have to listen to their complaints about the road. Jeeps are actually the worst, because of how they sway, and easy to lose control around a corner. This road can be particularly dangerous as it runs along a steep mountain side (with some very scary steep cliffs on the down side) and lake below. There have been quite a few accidents and some fatalities over time of people going over and into the lake.
So if this Solterra is as good as the ICE Subaru's, it will indeed be a hit with the mild off-road adventure crowd.
The graph could be more effective and they mentioned the need to improve their charging curve representation:Seems the Lucid is not as fast charging as originally thought. 20 - 80% in 31.5 min. The Ioniq 5 is 20 - 80% in 18 minutes. In fairness though, the Lucid does have considerable more range.
We have Kona Electric owners on the Forum who have bought out-of-state, but every dealership/state may be different.Kyle says go to another state to purchase an Ioniq 5. I called a dealership in Aurora Co. They said that they would only sell to someone who had the car registered in CO.
