GRU oil change
21KonaER
Hi all,
I had the GRU oil changed a week or so back by my local mechanic, using his four-post hoist (cost A$30!, using my oil). The local(?) (120km away) H dealer took a sample at the last service and I didn't like the look of it. I collected the old oil in a clean Alfoil tray and poured it into a clean glass jar. Please see photos. With full sun shinning on the jar it looks a metallic grey colour. With strong sun behind it, looks quite opaque.
I purchased an oil analysis kit last week and today, after giving the jar a good shake, took a sample. I'll post that off tomorrow and should have the results here by the end of this week. Will let you know the results.
For the record here are the current graphs of iron and aluminium content that I've been updating for many years. You also hold the record for the least-expensive non-DIY oil change. The most expensive was NZ$450.
Wow, that's great info, thank you. Have you come to any conclusions on OK Vs Unacceptable levels? And do any of your any samples relate to vehicles that subsequently had a GRU replacement?
When Brian (mechanic) said 30 bucks, I couldn't believe it. He and his off-sider (apprentice?) spent over an hour on it. Partly due to taking a punt and removing the rear plastic cover first... I think it may have been their first opportunity to have a close look under a full BEV (not that many here yet in rural SE Qld. - but improving since fuel prices took off thanks to you-know-who!)
By the way, I provided the Penrite 70W75 GL4 oil and two magnetic M18 plugs. Posting oil sample off this morning.
The two Leaf UOA included for reference are where we should be, under 150 ppm. Nissan used a fixed magnet on both plugs, one correct way to design and implement particle sequestration.
One datapoint is for a replaced GRU. But it doesn't matter as the root problem was never fixed. Note the graph X-axis are kms change intervals rather than accumulated.
If you do another oil change and are not typically driving over 110 km/h, you could install a 50/50 mix of the Penrite Pro Gear 70W-75 and 75W-85 giving you a 75W-80 PAO full-synthetic. I've used this for nearly 2 years now and I think the car runs quieter with no loss of economy.
Am I ever lucky enough to have you on line.
I am having a perfect day.
I just joined Facebook trying to locate my lost Daughter, later please.
Any idea on how to write a sentance?
If you reply with a message , that's incredible.
I think it would be prudent to private message.
Maybe try that?
By the way to all others, I just want to send a short greeting.
Hope you all had a wonderful day.
