On a 50kw charger you won’t throttle as fast, but on a 150kw it’s a different story: https://forum.abetterrouteplanner.c...ng-data-for-the-bolt-kona-niro-soul-and-leaf/
Exactly. The throttle starts much earlier (under 60% SOC) unless you're using a slow 50 kWh charger in which case you're starting off already throttled so it's a moot discussion.
Here is another graph that clearly illustrates the Kona throttle points:
https://support.fastned.nl/hc/en-gb/articles/360001029367-Charging-with-a-Hyundai-KONA
