KiwiME
The Model 3 gearbox has a pump-based oil system needed to support the more sophisticated lubrication management and use of a heat exchanger, therefore can support a filter. It appears that the motor is only cooled by oil, but lubricated by that as well.
The Hyundai motor is cooled exclusively by the coolant loop and the bearings are grease lubricated. The gearbox is oil splash-lubricated and (expectedly) has a magnet to catch wear debris, the most common arrangement for simple gearboxes.
They are just two different design philosophies. The more pertinent point regarding this thread is the bearing arrangement used by Hyundai, which happens to be similar to that used by the Nissan Leaf.
