The Gadgeteer
I think it's premature to say the problem can't possibly be this or that.
I agree. For all we know there can be a software issue on one end or the other.
Any chance of trying to charge a different Clarity on your Juicebox and see if it comes out different? Or charging yours on a different Juicebox where you can see the graph it makes?Having calmed down a bit after receiving the results from the Honda dealer I realize I have several options at this point.
1) A board member warned me that, in California, if I trade the Clarity in to buy a Clarity replacement before owning it for at least 30 months I will have to pay the state rebate back, or try to negotiate moving the remaining rebate to the new Clarity. So this may be an option, although this plan is now set back and can't be my top option.
2) Work with Honda to see if I can get them to make a repair. I'm convinced that there's something wrong with the car. As the ambient temperature increased heading toward summer the EV Range began to climb, twice even hitting 48 miles. Then suddenly on April 18th it dropped to 38-43 and the JuiceBox began reporting those saw-toothed charge graphs.
3) Just drive the car and see if the range and battery capacity continue to drop. I may be able to return to Honda in a few months or a year reporting an out-of-spec situation. We've had a few cool days and the range isn't going over 40.
I wish I could use my ODBII device to get the battery capacity number. Does anyone know how to do that?
4) Keep the car until the 30 months are up then trade it in. This may or may not be economical depending on values at that time. This will push me out to June 2020. I may be able to live with that. I'd have to pay attention to the continuing availability of the Federal Tax Credit to make sure it doesn't run out.
Still deciding...
I've seen a couple of Claritiy cars in the city. At this point I'm convinced the JuiceBox isn't the problem. I charged the car on 110V and, while it didn't generate a graph, it didn't charge any better than the JuiceBox. Also now the Honda dealer has charged at their site and only achieved 39.9 EV Range.Any chance of trying to charge a different Clarity on your Juicebox and see if it comes out different? Or charging yours on a different Juicebox where you can see the graph it makes?
Nominal battery capacity is 55 Amp-Hours (17.6 kWh at 320V).
Warranty for battery is 8 years with capacity above 36.6 Amp-hours (2/3 of original capacity).
With your measured value of 49.6 Amp-Hours, your capacity seems to be at 90% of original capacity. If you lost 10% every year like this, it would fall out of the warranty limit well before the 8 years.
I don't disagree with you. You are measuring the situation one way with a certain set of evidence. The dealer/Honda is measuring the situation a different way using a different set of evidence. I'm just suggesting that some additional evidence. A different car doing the same thing on your Juicebox points to the Juicebox. If it doesn't do it, then it points to your car. If a different charger gives the same graph with your car, but not others, that points to your car. I think the dealer will have a more difficult time dismissing that evidence. At the very least, such tests will tell you something.I've seen a couple of Claritiy cars in the city. At this point I'm convinced the JuiceBox isn't the problem. I charged the car on 110V and, while it didn't generate a graph, it didn't charge any better than the JuiceBox. Also now the Honda dealer has charged at their site and only achieved 39.9 EV Range.
In the winter we've been getting close to running out of battery charge already. 30 mile trips are almost a daily occurrence here. When the cold winter days have dropped range below 35 we come close. With this range degradation I expect next winter we will have to rely on the ICE for a small portion of the trip. This is a double whammy as we charge with solar when possible. Winter days often don't produce enough to run the house and charge the car. So with the range deteriorating we not only may have to use some gas but we will also use additional grid power.This is an issue that those who have researched solar may be familiar with - when a panel is warrantied to not drop below X% in Y years, is that a flat limit (i.e. X% in year 1 still meets spec) or a prorated curve (linear from 100% to X% over time)? Cheaper panels are often the first case, whereas some higher quality panel manufacturers have chosen to make a prorated warranty one of their selling points (and indicator of quality, that they stand behind their products better).
So, which approach will Honda take? Given that warranties are not a major competitive item for automobiles, I would guess that officially it is a flat limit. However, I see two arguments you could make to get them to replace it now:
1 - with this trend line it will clearly fall below spec, so they should replace it now for the customer satisfaction karma (i.e. avoid social media problems)
2 - if your battery is degrading they should take it back to R&D to tear it down and learn from it. Given that another forum member was contacted randomly (?) to have their battery taken to R&D, maybe you can ask for contacts to reach out to those managing that program directly.
Your third option, of course, is to keep driving the car. If your trips tend to be less than 30-35 miles roundtrip then perhaps it wouldn't affect your use that much. And it gives it time to fall the rest of the way out of spec.
Why in the world did they not make the battery replaceable at the module-level? It would be in everyone's best interest (us customers, Honda, insurance companies) if it were possible to replace just the defective portion(s) of a battery.
The BMS is also likely to have this same modularity...
Putting new cells into a used pack causes the entire pack to be out of balance
my guess is that each added module will have to have its own independently functioning BMS, just as each has to have water-tight connections for the cooling system.
