Toolworker
Might be worth a look.Where is the ground rod servicing the subpanel? If you're comfortable with removing live panel covers (or turn off the subpanel from the main panel), it would pay to check and tighten the connections from the ground rod all the way to the wall EVSE.
Right. But maybe the car only checks for ground at the start of ABS.But it looks like the ABS succeeded with no EVSE connected but also was not disturbed by connecting the portable unit during the event.
And just to note, ABS stopped early when HV charging finished.
