evse recommendations?
Discussion in 'Cooper SE' started by KeninFL, Jun 13, 2020.
  1. bldxyz
    bldxyz Well-Known Member
    Actually, the issue is not my dryer outlet, is it the outlet at my in-laws' place. And I'm quite certain that outlet does not have GFCI.
    So if the EVSE doesn't handle any sort of ground protection, there is a risk around grounding, no?
  3. F14Scott
    F14Scott Well-Known Member
    Since you already have 3 wires rated for 30 Amps running from the panel to that outdoor box, it would be pretty easy for an electrician to swap the breaker for a double pole GFI (to give you 240V and GFI to an outdoor outlet) and swap the TT-30 to a 10-30 outlet. Then get one of these:
    https://smile.amazon.com/dp/B08GP81NY1/ref=cm_sw_r_cp_apa_fabc_BAZF8BE77CFWGKF8QX8Q?_encoding=UTF8&psc=1
    You'd be charging at 24A/240V, so a full tank from empty in about 5 hours. Pretty sweet, for probably $600, all in.
    MichaelC likes this.
  4. insightman
    Have the in-laws been in your SE yet? After they take it for a spin, they will be convinced they cannot live without one of their own. Then THEY will be the ones paying for the EVSE and installation. Easy-peasy (except for getting them to install the EVSE at the beginning of their long wait for their SE).
    GetOffYourGas likes this.
  5. bldxyz
    That's price-prohibitive for this use case, since we have an ICE car that is roomier and the car most likely to make that trip. It's really only likely to happen once or twice a year, at most, and so I'm either going to need to find a solution that fits the infrastructure that exists, or a public charger.
    Extremely unlikely.
    I tried to convince my Mother-in-law to look at EVs and even PHEVs, but she didn't even end up with a hybrid when she bought her last car two years ago. Her hub is very unlikely to step down from his large truck to a small SE, and through thorough conversations with him today, it is clear that he cannot see past range anxiety.
  6. Lainey
    Lainey Well-Known Member
    It's always strange to me how 'stubborn' people are about cars. I held off for a while because I loved driving stick. I needed to know if an electric car could be just as fun. I started off with a fuddy duddy Leaf. Minus the steering and such, it was fun off the line. Love one pedal driving. But when I talk to others they are like "I just don't know about those cars" like they are alien or something...
    The SE is a ton of fun though. More so than my last Mini.
    GetOffYourGas and bldxyz like this.
  8. bldxyz
    At least in this case, age could be a factor. How many people in their 70s and 80s are adopting things on the upslope of the adoption curve? I’m sure some are “early adopters”, but I bet the demographics of tech adoption tends not to favor the senior set.
    Even though all of us here are adopting, I will offer that I, myself, am just now buying my first EV of any kind. And I remember thinking in 1993 that the car I bought then would be the last, non-electric car I would buy. (It wasn’t, but I’m just saying that this adoption curve isn’t like, say, Facebook.)
  9. Lainey
    It is hard to shift, that's for sure. My late 70s dad thinks his next will be an EV as well. Kind of proud of that willingness. Many of his friends are in the nope category
    Even I was no early adopter in this case. In fact I intentionally bought my last car as one last hurrah with a manual. It took years for me to drop the idea of having an ICE vehicle
  10. bldxyz
    I would argue that we are still in the somewhat early phases of EV adoption, though not the earliest. We aren't quite to mainstream adoption yet, given the market share of EVs.
  11. GetOffYourGas
    Does anyone here know if the SE can pull more than 12A at 120V? I know the Bolt will only ever pull up to 12A, and that's a limit imposed by the car. Technically, the J1772 standard defines 120V up to 16A - 120V / 24A is not valid under the official protocol. That said, even 5-20 outlets are pretty common. The 33% boost in charge rate from 12A to 16A is not insignificant.
  13. Lainey
    My sister in law is on her 2nd EV. Makes me feel late to the game lol
    bldxyz likes this.
  14. Recoil45
    Recoil45 Active Member
    Not sure why you don't see that as reasonable. I came to this forum because I had interest in the Mach-e but had concerns. I figured they were unfounded, but after reading things here for months I underestimated the issues with EVs. The tech simply isn't right for some of us at this time. Unless you have strong feelings about being green, it seems best to wait a few more generations for me.
  15. GvilleGuy
    GvilleGuy Well-Known Member
    I’m just curious what the show stoppers are for you at this time?
  16. Puppethead
    Puppethead Well-Known Member
    For North America, the Owner's Manual says max Level 1 is 15 A. But the charge cable the SE comes with maxes out at 10 A.
  17. bldxyz
    My brother is on his second Prius. Straight hybrid versions, both. He can still claim superiority when we get this SE since our other car is a pure ICE.
    Lainey likes this.
  18. Lainey
    Yeah but they're driving a Prius. Not superior to much... :D
  19. bldxyz
    Sorry, but I’m not sure which part of my message you are referring to when you say, “not sure why you don't see that as reasonable.” I can try to explain my reasoning if you clarify your question?
  20. bldxyz
    Well, I said he can claim superiority, as he has had a tiny tiny bit of that going on since he bought his first Prius. I mean, sure, he was getting something like 50 MPG when the rest of us were getting about half of that, so he could claim he was saving the planet.
    Nonetheless, I did laugh at your joke!
  21. GetOffYourGas
    Thanks. I have read the owner's manual, but this is the most confusing manual I have ever read. Half is poorly translated english (isn't Mini supposed to be a British car?) and there is a lot of conflicting information. I also found many references that suggest european electric standards.
    I used to have an EVSE setup that could do 16A / 120V, but I no longer have it. Otherwise I would test this out myself.
  22. Lainey
    German parent company though.
  23. GetOffYourGas
    Yes. And that is very apparent to me in the owner's manual.
    Lainey likes this.
