2022 Mini SE - In Focus: Range!
Discussion in 'Cooper SE' started by GvilleGuy, Aug 22, 2021.
  1. Denise C
    Denise C Active Member
    So far so good! Thanks for creating the shortcut and saving data into notes
  3. GvilleGuy
    GvilleGuy Well-Known Member
    You're welcome! Thanks for testing it. @fasttr (I'm not sure how active they are on here) did most of the work on the Notes thing. I just had to tweak it and get it working on the current IOS version. I'm going to like having the automatic 'history' build up. And I'm VERY glad @Puppethead pointed out how my numbers were off when starting battery was less than 100%. That was a bad error in my math.
    Denise C likes this.
  4. Puppethead
    Puppethead Well-Known Member
    Here are my two trips from yesterday, with a mid-day charge up to 74% SoC:
    Jan 28, 2022 at 12:49 *** Driven: 41.2 Mi *** Mi / kWh: 3.48 *** Range Left: 59.34 Mi *** Total Range: 100.54 Mi
    Jan 28, 2022 at 17:34 *** Driven: 42.6 Mi *** Mi / kWh: 3.78 *** Range Left: 38.23 Mi *** Total Range: 80.83 Mi
    Looks like the new EV Range is working great, I ended up with about 38% SoC when I got home. thanks @GvilleGuy!
    (Although looking at the numbers I'm curious why the second leg was more efficient but had lower total range...)
    GvilleGuy and Denise C like this.
  5. GvilleGuy
    Thanks for letting me know! That IOS note format lends itself well to pasting into the forum!
  6. GvilleGuy
    Thinking more on this, I think I will add start and end battery charge data to that output. Might as well…
  8. Torrey
    Torrey Active Member
    Is the range for the second leg from the 74% SoC? So while more efficient you didn’t exceed the 100 mile calculated range of the first leg. If the second leg had the same efficiency, then the calculated range would have been 74 miles.
  9. GvilleGuy
    I put Mini SE Range v2.1 out there - it now sends the start/end Batt % to IOS Notes:
    https://www.icloud.com/shortcuts/73b6f9ebae734357883a6899b9d248ea
    Jan 29, 2022 at 7:11 PM *** Driven: 112 Mi *** Start-Batt: 94% *** End-Batt: 12% *** Mi / kWh: 4.73 *** Range Left: 16.4 Mi *** Total Range: 128.4 Mi
    Urbanengineer, drdunkyn and MichaelC like this.
  10. Puppethead
    Yes, but shouldn't the total range actually go up with a higher efficiency? Total range should be battery capacity * mi/kWh, right? The actual SoC for beginning/end would affect mi/kWh, but I wouldn't think it would change the total range calculation. Unless I'm missing something.
    Update: I think I figured it out. It seems the total range is based on the amount of charge minus the mile driven. So in my example, 42.6 miles driven and 38.23 calculated miles left = 80.83 miles range.
    Maybe two values, "range for this charge" plus a "total range for full battery", if that's doable. I was seeing "total range" and thinking of whole battery, but it's really "range based on current charge and current driving efficiency". Data analysis can be so tricky.
    drdunkyn likes this.
  11. GvilleGuy
    Take version 2.2 for a drive and see what you think.
    IOS Shortcut link:
    https://www.icloud.com/shortcuts/4b7c570dbed4411498f6c5ab0c903c7d
    (IOS Notes) Mini SE Range History
    Jan 31, 2022 at 1:40 PM ** Driven: 86.3 Mi ** Start-Batt: 90% ** End-Batt: 19% ** Mi / kWh: 4.21 ** Range Left: 23.12 Mi ** Total Range (From 90% charge): 109.42 Mi ** Total Range (From 100% charge): 121.669 Mi
    Jan 31, 2022 at 1:43 PM ** Driven: 58 Mi ** Start-Batt: 77% ** End-Batt: 31% ** Mi / kWh: 4.36 ** Range Left: 39.06 Mi ** Total Range (From 77% charge): 97.06 Mi ** Total Range (From 100% charge): 126.004 Mi
  13. Puppethead
    Looking good! Thanks!
    Jan 31, 2022 at 17:57 ** Driven: 83.9 Mi ** Start-Batt: 100% ** End-Batt: 26% ** Mi / kWh: 3.92 ** Range Left: 29.45 Mi ** Total Range (From 100% charge): 113.35 Mi ** Total Range (From 100% charge): 113.288 Mi
  14. GvilleGuy
    I am learning more about Shortcuts every day from working on this - I will probably add an "if then" statement and suppress displaying the 'extra' total range line when start-batt is 100%.
  15. Thanks for the updated shortcut. I updated my version to capture weather data as well with hope that it would help in the long run to see how weather affects the range.
    GvilleGuy and MichaelC like this.
  16. Adam Berti
    Adam Berti New Member
    Cool. Watched your video and learned some things around the exact battery and trip odometer!
    That’s a pretty neat use of shortcuts too - I’ll try it out!
    GvilleGuy likes this.
  17. GvilleGuy
    Fantastic idea! I updated my version to include location-based temp, wind speed, and humidity. I will test it a bit more before releasing the link. I wanted to add dew point, since dew point is selectable data within the shortcuts weather function, but it apparently has not worked for a while. So I just used humidity.
    Feb 2, 2022 at 5:42 PM ** 48.2°F ** Wind: 8.078 mph from NE ** Humidity: 50% ** Driven: 99.1 Mi ** Start-Batt: 100% ** End-Batt: 24% ** Mi / kWh: 4.51 ** Range Left: 31.28 Mi ** Total Range (From 100% charge): 130.38 Mi ** Total Range (From 100% charge): 130.339 Mi
    Feb 2, 2022 at 5:44 PM ** 48.2°F ** Wind: 8.078 mph from NE ** Humidity: 49% ** Driven: 58 Mi ** Start-Batt: 76% ** End-Batt: 34% ** Mi / kWh: 4.78 ** Range Left: 46.97 Mi ** Total Range (From 76% charge): 104.97 Mi ** Total Range (From 100% charge): 138.142 Mi
    EDIT: Shortcuts provides wind direction in degrees of 360. Not very user friendly. I had a LOT of trial and error to convert degrees to N, NE, E, SE, etc! I finally found someone else’s code snippet and adapted it to my script.
  18. Puppethead
    Here's my real run today with a mid-day charge. Considering the change in efficiency I like what it shows.
    Feb 2, 2022 at 12:40 ** Driven: 46.3 Mi ** Start-Batt: 100% ** End-Batt: 48% ** Mi / kWh: 3.08 ** Range Left: 42.73 Mi ** Total Range (From 100% charge): 89.03 Mi ** Total Range (From 100% charge): 89.012 Mi
    Feb 2, 2022 at 18:34 ** Driven: 39.2 Mi ** Start-Batt: 62% ** End-Batt: 15% ** Mi / kWh: 2.89 ** Range Left: 12.53 Mi ** Total Range (From 62% charge): 51.73 Mi ** Total Range (From 100% charge): 83.521 Mi
  19. GvilleGuy
    Thanks for posting! I think this shortcut is starting to take good shape!
  20. Quiet Mini
    Quiet Mini Well-Known Member
    Driven: 85 Mi
    Start-Batt: 100%
    End-Batt: 44%
    Mi
    /kWh: 5.25
    Total Range (From 100% charge): 151.76 Mi
    Total Range (From 100% charge): 151.725 Mi
    ESTIMATED RANGE REMAINING: 66.76 Mi
    I’m pretty impressed with these numbers especially since it involved driving from 5,000ft elevation to 8,500ft and back.
    Thanks for the shortcut. Out of curiosity, why do you have the input as a decimal vs adding a divide by 100 step in the calculation?
    wessy likes this.
  21. SpeedyRS
    SpeedyRS Well-Known Member
    That’s amazing. What mode were you using to achieve that figure? I don’t get anywhere near that, but I only really use mid or sport modes.
  22. Quiet Mini
    This was in mid. To be fair the 30 miles of climbing was a 35-45mph winding canyon so it’s not like we were going freeway speeds.
  23. GvilleGuy
    Just personal preference.
