I'll just add what I posted over at UK site SpeakEV where they also have such problems.
@KiwiME, @mikeselectricstuff - A meta-question: Can you post links to other threads that discuss the dead 12v battery problem? Is there one good place to focus on it?There are plenty of reports of dead 12v batteries ...
Well I guess its my turn with this 12V battery saga ...
@apu, @electriceddy - Were you plugged into your EVSE when you found the battery dead? What model EVSE?Woke up to a 4.6 V battery this morning ...
The car was not plugged in or charging@KiwiME, @mikeselectricstuff - A meta-question: Can you post links to other threads that discuss the dead 12v battery problem? Is there one good place to focus on it?
I started this one and posted a graph and video documenting my EVSE and the Kona in a loop that drains the 12v battery. I'd be happy to combine it with another one specifically on the topic.
If it followed the 24 hour cycle , it should not have come on until late Friday afternoon as I drove the car on Thursday (the day previous) and parked it about 3pm. It had to have been triggered by low SOC as you mentioned.As I alluded to in an earlier post the lower voltage may be due to the LDC current limiting when charging from a very low SoC. Check the image in post #78. The aux battery could also have been damaged but my guess is that it will come right after a proper charge. The bigger question is why did it discharge so far down?
The lessor question that I have is why you thought the aux saver event was unexpected? I've never seen evidence of that function operating at any time other than on a 24 hour schedule after the completion of the last normal drive but would be happy to be proven wrong, especially if it was triggered by a low aux battery SoC. It may have just been the scheduled time as it's not restricted to nighttime.
I'll just add what I posted over at UK site SpeakEV where they also have such problems. This is what I understand happens to the aux battery so far:
While charging it should be around 14.65 V. That may be affected with temperature compensation that I haven't encountered during our summer.
While parked it will should start from a peak around 13.1 and drop slowly due to quiescent draw, normally to around 12.8 before the next aux saver event kicks in. That seems to be the period where dead battery problems can arise as the aux saver doesn't seem to be able to save itself if the voltage drops too low. There is new evidence from one of our fellow owners that each charging period doesn't compensate for prior higher losses so I would speculate that losses due to abnormal current draw can accumulate over several days if the car is parked and relying solely on the unfortunately-named aux battery saver. Eventually the voltage will be too low for the systems to operate.
- It only charges for around 10-20 minutes at the start of each driving or charging event.
- Same with aux battery saver events which trigger daily once the first 24 h period has elapsed after the last proper drive, meaning over about 20 min. Shorter drives, moving the car, opening a door, or entering Run mode to check something doesn't reset the trigger or disrupt that schedule.
While driving or charging past the "charge" period of 10-20 min, the system voltage will suddenly drop and dither just above 13 V for the duration of the trip (or charge) as the system (LDC) maintains a high-enough voltage as to draw effectively nothing from the aux battery. That system voltage is quite noisy so don't rely on random spot checks. 12.9 to 13.4 is perfectly normal for this period.
As I also mentioned, I've seen evidence that the car tests the aux battery, and I'll wildly speculate that it's trying to determine the health. It seems the i3 also tracks battery health and apparently there is a procedure required after a new battery is installed which owners refer to as 'registering the battery'.
There is a bit more technical expertise here, best just keep it here in this thread. I barely get a 'like' over there, and never a 'thank you' for providing info.- A meta-question: Can you post links to other threads that discuss the dead 12v battery problem? Is there one good place to focus on it?
Just want to say, I for one, am grateful to have you and others on this forum provide such technical and useful insight to some of the problems/issues with our cars. I may not always respond or like (I should do more of the latter), but am certainly following. Keep it up...There is a bit more technical expertise here, best just keep it here in this thread. I barely get a 'like' over there, and never a 'thank you' for providing info.
Please post here, and can you give us a link to the Ioniq forum discussion(s)? Maybe we can get this all in one thread, so all of us with the same problem are talking with each other.Thank you for your efforts, most interesting reading. You inspired me to look more closely at my 2019 Ioniq electric 12V system. Ioniq electric owners are having the same, or similar 12V problems. <snip> May I post some ioniq electric results here, or would you prefer that I start a new 12V thread in the Ioniq electric forum?
I'd sure like to see any results either here in this thread or as a link to an Ioniq thread. I have no easy access to such useful kit. Formulating a test plan that will identify the fault(s) is the challenge. Do you have BlueLink app capability on your Ioniq?May I post some ioniq electric results here, or would you prefer that I start a new 12V thread in the Ioniq electric forum?
I'm unsure that the LDC would wake up just to support a request from BlueLink. Checking LDC output would clearly show if it does, as possibly would the accompanying battery terminal voltage. I think though the takeaway is that the current draw due to a BlueLink request is short, under 1 second at about 22 amps, 79 mWh if my math is correct. Could the 300uS pulses coincide with receiving the request?...So, the first odd thing is that I'm seeing readings approaching 30 mA (4-20 mA loop, with some under range to -10A), which assuming the sensor is working properly means some over scale reading above 50A.... Is that just charging some capacitors somewhere, starting the LDC?, or are there two very short (300 microseconds), short circuits?
I would imagine that's all it can do without knowledge of aux battery current and terminal voltage. It seems the LDC has just two "on" modes, charging at that fixed voltage, or dynamically adjusting system voltage to ensure that the battery sees no net discharge current, effectively a very slight charge current.Today I pulled the little connector out of the current-sensor, fired up the car, and went
out on a small errand. The voltage quickly rose up to 14.7 and basically just stayed
there... _H*
Just as you expected, it came back to full life on its own - after jumping it and leaving the car charging on an L2 for about 4 hours. Dealer Tech said another "ghost" and I will have to monitor for any more issues.As I alluded to in an earlier post the lower voltage may be due to the LDC current limiting when charging from a very low SoC. Check the image in post #78. The aux battery could also have been damaged but my guess is that it will come right after a proper charge. The bigger question is why did it discharge so far down?
