The title can be changed. Long press the gauge, then "Display configuration ..."000_Battery Power (misleadingly named Energy Draw on the gauge) (change to 1, 2 or 3 decimal places)
I've seen mention of security concerns, particularly if a dongle uses a fixed pairing code like 0000 or 1234 and the dongle is left plugged in when the car is unattended.Any insights on whether any ODB2 with bluetooth will do?
Do some ODB2 scanner offer fewer bits of information than others?
006_Speedometer_Check,Speed,,((VAL{000_Drive Motor Speed 1}*60)/7.981))/484.4,0,200,kph,
I never had needed or tried to push files from my computer onto my Huawei Mate 20 Pro so it took me much longer than I had expected to perform step A from the instructions below for installing the PID files. I'll explain what I did as maybe it will help someone else someday.
I had prepared the combined csv file on my computer and then plugged my phone to my PC (windows 10) using a USB cable. I thought doing so would trigger the old plain and boring File Explorer but no...... To access the phone, I was forced to install some "new and improved" software from Huawei. And the damn thing does not even have a setting to view hidden file.
After some frustrating moments and more searches I came across a workaround. I uninstalled the software, unplugged the cable from my phone and connected my PC to my phone using bluetooth instead of a USB cable. Turns out that in the bluetooth section of windows 10 there is a feature named "Send or receive files via Bluetooth". That allowed me to finally get my files into the proper subfolder within the .Torque hidden folder.
So if you are using Windows 10 and have Huawei phone, forget about the USB cable. Go straight to bluetooth.![]()
Thanks - that works.Most default Torque Pro pids don't work with the Kona.
If you know about Torque Pro .csv files, then the following pids will be helpful. Dump them in a text editor with no formatting, save in .csv format, copy to the /torque/extendedpids folder on your phone, then add the folder to Torque using /Settings/Manage_extra_Pids/Sensors/Add_predefined_set. They are based on the notion of EV's having direct drive from the motor, not via a gearbox. A suitable multiplier/divider will provide mph.
006_Average_Speed,AvgSpeed,,tavg(3600:VAL{006_Speedometer_Check}),0,100,kph,
006_Trip_Distance Trip,Trip/km,,TOT(3600:VAL{006_Speedometer_Check}),0,500,kms,
There are a few simpler ways to transfer files between devices. I ended up using Google Drive. But the easiest way is to e-mail them to yourself.
The /Torque folder or the /Torque/extendedpids subfolder? I assume you mean the latter, a nice way to do it. I have mostly not had to do this with Samsung models - maybe it's phone related?I got my obd2 reader yesterday. Got it going pretty quickly other than that I had to save a custom pid first because the .torque folder wasn't created at all before that.
Nope, for some weird reason it was the top folder named .torqueThe /Torque folder or the /Torque/extendedpids subfolder? I assume you mean the latter, a nice way to do it. I have mostly not had to do this with Samsung models - maybe it's phone related?
