What version?Looks like the update i got in early May , is the latest update.
Yes, only the navigation needs the cardIs it OK to take out the car's SD card and drive it? My wife wants to go shopping right now, and would like to remove and set it up, if that is OK.
Just curious if I got it right, once the download completes on the SD card, you just close the program and then install the card into the car and push system update? ( don't manually download to PC?)View attachment 5390 View attachment 5390 Got my update completed. Did have a few interesting moments. First it didn't like my SD card from the car, that I had just deleted the old files. Reformatted it and then it worked. Took forever to complete on the SD card. Stayed at 1% for the longest time, and had me wondering if it was in some kind of loop. But I kept checking Properties, and it was slowly building the files. It finally did complete, but then the Manual download wouldn't work on my computer, did not seem to like my Adobe reader. However, I had another version of it downloaded separately, on how to update it in the car.
So I turned on the car, and inserted the SD card with the new map update. It then told me the SD card was incompatible. However, I proceeded to the System Update, and it seemed to be good with it. So not sure what that was all about. Anyway, I did the Update, and it finished in about 20 min or so. And everything seemed to come up properly, and all looks good. So I guess it worked.
I attached a pic with the new version info. I see the only diff from the prev poster is the first line where it shows 190504 instead of 190401. But the version number is the same.
You first download to the PC, then to the SD card, which you stick back in the car, where you do the Update. Here are the instructions, pretty self explanatory.Just curious if I got it right, once the download completes on the SD card, you just close the program and then install the card into the car and push system update? ( don't manually download to PC?)
Found this describing "Iron man edition"I'm in the U.S. and got notified of a map update (v NA.12.41.51.593 (v13.0)). So far, so good. When I log into mapnsoft.com to download the map update it identifies my Kona EV as "2019 Hyundai Kona (Iron Man Edition)". Well, I know my Kona EV is based on advanced technology, but having seen an Iron Man Edition Kona, I can tell you mine isn't one. Dare I install this map update into my non-Iron Man Kona EV? Will it suddenly sprout wings?![]()
Yeah . Maybe because I downloaded the map a few months ago . It has bugs and this new version was issued to fix them. I should be able to download it too, but the link is missing on the page for meYou shouldn't have to pay!!?? Mine was free, just a software download. Did it just yesterday.
