Still confused. Is the car linked to my cell phone with Bluetooth or something else? If something else then what?Tiralc just did the research for me. So our vehicle must communicate back and forth with our phones. That's how it gives us the vehicle location, how we tell it to start the climate control, etc. Thanks for the info!!
1. The whole MPGe model is baffling to me. In 801 miles I have used 6.3 gal gas (@$2.54/gal) and 174 KWh at approx $0.12/KWh. If I assume I've used about 8.2 "gallons" of electricity, for a total of 14.5 gal - does that mean I have a 55.2 MPGe? Really good, but not outstanding.
From what I understand, the Bluetooth connection is completely separate from the connection to the TCU.Still confused. Is the car linked to my cell phone with Bluetooth or something else? If something else then what?
If the car is only linked to my cell phone via Bluetooth then it has only a 90 foot range. Can't communicate with the car if I'm farther away than that.
I think it's a HUGE mistake to try to blend EV miles with gas-powered miles, when figuring fuel economy. For PHEVs, gas-powered miles and electric-powered miles should be counted separately, and any comparisons with other cars should also be made separately. Mixing the two together says a lot more about a driver's individual driving/charging pattern than it does about the performance or energy efficiency of the car.
For example, if Driver A goes out of his way to make sure he burns as little gas as possible, either taking only short trips or by stopping for an en-route charge whenever the battery pack gets low, and if Driver B doesn't worry about it, and lets the car burn gas as necessary until it's put back on the charger, does that in any way help a prospective car buyer know what MPGe he would get if he started driving one?
Of course not. A high MPGe or -- if you're driving a Volt -- a high fake "MPG" rating* is useful only for bragging rights for the driver.
For PHEVs, the EPA ought to give separate ratings for MPG in gas-powered mode and MPGe ratings for energy efficiency in EV mode. (Well, better, it should dump the very confusing "MPGe" metric and use something more appropriate, such as kWh/mile or miles/kWh. EPA ratings do include a "kw-hrs per 100 miles" in smaller print, so that's at least something.)
*The Volt's computer adds EV miles and gas-powered miles for a fake "MPG" rating which is displayed on its instrument panel.
The only choices are Bluetooth or cell. If not Bluetooth, and we assume the car does not have cell capability then what?From what I understand, the Bluetooth connection is completely separate from the connection to the TCU.
Tiralc, yup, I can still turn on my climate control wherever I've tried it. Malls, free-standing restaurants, etc. No other phones sitting in the car. Go figure.
Have I just not been in an area where this is not possible? If so, what's the missing ingredient that would cause this? It would seem if it's truly relying on an open WiFi, with no password required, that would seem a real security issue.
I like to brag.I think it's a HUGE mistake to try to blend EV miles with gas-powered miles, when figuring fuel economy. For PHEVs, gas-powered miles and electric-powered miles should be counted separately, and any comparisons with other cars should also be made separately. Mixing the two together says a lot more about a driver's individual driving/charging pattern than it does about the performance or energy efficiency of the car.
The EPA does give you separate ratings when in gas mode vs electric mode. If you look at your window sticker, it says something like 42 mpg combined using gas engine, and 110 mpg-e when in electric mode.
I like to brag.
Yup, I totally agree with you. I don't know why these gauges are so inaccurate. I've never seen anything quite like it. Aside from the lack of a backup alarm, I think this is the most serious issue of the Clarity.Back to issues:
THE FUEL AND RANGE GAUGES ARE WORTHLESS.
Seriously - I drove 155 mile in HV mode; 4.23 gal; after refueling it said I had 515 miles HV range. Drove another 64 miles and it still showed 472 miles range (guess that's an improvement), but not a single tic off the gas gauge.
Meanwhile, I noticed what I would call as "battery leakage." During that first 155 miles of today's adventure I had it in HV mode the entire way and lost 17 miles of EV range (from 48 to 31). My reading of the manual says it is supposed to preserve the battery for EV use at your end point - not so much.
Likewise, now at my destination, it shows 13.5 miles EV but nearly 1/2 battery remaining on the gauge.
My Prius was far more accurate on fuel usage, and usually within 2-5 mpg of calculated consumption. What gives?
Everyone has their own likes and dislikes. In my case one of the first things I did when we purchased our 2015 Prius, then the Clarity, was turn off the backup alarm. In the Clarity it is only a single beep when the car is put in reverse. The Prius would beep continuously INSIDE THE CAR when backing up until that feature was disabled.Yup, I totally agree with you. I don't know why these gauges are so inaccurate. I've never seen anything quite like it. Aside from the lack of a backup alarm, I think this is the most serious issue of the Clarity.
