Thanks @Danks !
I was just catching up on this thread after being away for a bit and the #1 item that seems to kill the battery is heat, even with the Clarity's active cooling.
My battery capacity situation is very similar to what @Miles777 had experienced with his 1st Clarity. Both of us live in the desert southwest with temps hitting 115+
Here are my readings.
08/09/2025 48,414 mi 41.26
10/30/2024 43,858 mi 41.72
01/25/2023 29,474 mi 44.64
07/15/2022 25,560 mi 45.58
03/24/2021 21,888 mi 47.40
I bought my car in Sep 2018 which means the battery warranty should be thru Sep 2026.
It is going to be an interesting race between time and heat.
On another note - it seems that Honda or the dealer is trying to wiggle out of Warranty on used cars
https://www.clarityforum.com/thread...standing-or-is-honda-not-honoring-terms.1920/
Thanks @Danks !
Add me to that list. Bought the car new in Jan 2019. First time I measured the battery capacity was after seeing a dramatic loss in range in the summer of '22 after moving to Vegas, it was reading 52 Ah. It kept like that (reading it every month) until the following summer, when it suddenly dropped to 50.72. Same thing again the following summer, dropping to 49.7 and stayed like that until I moved to Phoenix early in 2024, but there was no noticeable change until midsummer, when it suddenly dropped to 49.2. Now when I last read it in July it was already sitting at 48.7, but in recent days I noticed a sharp drop in range again (from 48 to 41 miles). Haven't had the chance to measure the battery yet, but I wouldn't be surprised to find it at 47 Ah or less.
Thanks @Danks !
I'm in Florida so 6 months in the nineties but never over 100. I have also noticed more degradation during the summers, about twice as much as winter, but not near as bad as you.
I'm at 101k miles on my 2018 with the battery at 44.2. The rate of degradation was greatly reduced year round starting 2 years ago when I changed my charging habits. I now minimize the time the car is sitting at 80-100% and 0-10%. I charge to around 80% over each evening, then start charging again in the morning while I have breakfast etc then drive away before its 100%. Over the last 4 (hot) months I drove 4000 miles and it went from 44.50 to 44.21. I still get about 54 miles actual (no highway) from a full charge even with cheap crappy walmart non-ev tires.
I think it is pretty cool that these cars are still getting 50+miles of battery range if driven 40-50 mph. I don't have the patience to manage the charging level on the Clarity, and I'm a little behind @David Towle at 43 Ah with 70k miles, but I can still surpass 50 miles on EV when not driving at highway speeds. But, if you have the time and patience to manage the charging on the Clarity, I am sure it is good for the life of the battery to do so.
On a full EV with say 300 miles of range with onboard software to set the charge limit, this is much easier to accomplish on a daily basis (it essentially manages itself). I rarely need full battery during the week on the EV, so I set the limit to 75% and usually charge once a week to bring it back to 75% when it drops to about 40%.
We also have a full EV, A Tesla Y, and agree it is much less effort to manage the battery. Although the difference would not be as bad if the Honda app had the functionality of the Tesla app.
One key to still getting high miles per charge on the Clarity is to minimize the use of regen. Once you've accelerated, coasting is a much more efficient use of the power.
I'm at 101k miles on my 2018 with the battery at 44.2. The rate of degradation was greatly reduced year round starting 2 years ago when I changed my charging habits. I now minimize the time the car is sitting at 80-100% and 0-10%. I charge to around 80% over each evening, then start charging again in the morning while I have breakfast etc then drive away before it’s 100%. Over the last 4 (hot) months I drove 4000 miles and it went from 44.50 to 44.21.
Correlation doesn’t mean causation. We know that degradation isn’t linear. Laboratory testing has demonstrated that for us. Multiple variables need to be considered.
As an example, discharge rates and conditions are as much of a factor as charging habits. Often times we have very little control over discharging the battery. In cold weather at high speeds or in hilly terrain the battery could be depleted in 15-20 minutes. That’s a rapid discharge which is not ideal for battery longevity.
Didn't you relocate from New England to Florida a couple of years ago? Was that about the same time that you also changed your charging protocol? You also changed the climate and terrain where the vehicle is operated. Quite likely your driving patterns changed as well. Combine just the few variables mentioned thus far, with the high probability that you saw the most significant levels of degradation within the first year or two of ownership and you may come to realize that what you’re measuring now is just baked in the Lithium cake, regardless of the subtle modifications you’ve made to your charging regimen.
We relocated 5 years ago. Had plenty of data in Florida before the change in charging. No changes in driving conditions in the last 5 years.
Would charging in very high ambient temperature also help degrading the battery?
Yes. Let’s first remind ourselves that charging the battery under ideal conditions degrades the battery as well. In a nutshell, everything causes battery degradation.
That said, Honda, like most manufacturers, employs a battery cooling system in addition to a Battery Management System (BMS) which protects the battery by regulating charging and discharging. If you are able to charge the battery, Honda has determined that it is acceptable to do so.
Will regularly charging at 135F rather than 77F degrade the battery at a more rapid pace? Probably. Good luck measuring that. Besides, what options do you have? Are you going to leave the car in a climate controlled garage during the 6 months of sweltering heat?
New owner of a 2018 Clarity. I have gone thru the 37 pages to try and get my cheap Amazon ELM dongle to work with both the torque app and Car Scanner just to get the Capacity and no luck. Entered the custom PID code on page 1 with no luck. Shows no data when I test.
I downloaded the PID packs for car scanner (both the cbz and csp files) and the PIDs show up in my dashboard but im still not getting any data. Could it be the ELM dongle I'm using just cant keep up? If I have to buy the vGate iCar Pro so be it, just figured I wuld ask before.
Was there ever a PID pack for the Torque App? I looked on every page with no success.
Thanks in advance!!
@Conelite: I am sorry that you wasted your time with the "37 pages".
This was a work-in-progress at that time and there is a LOT of clutter here that is very difficult to sort through.
It is highly likely that your ELM adapter is one of the bad ones.
We have a much more concise thread (not 37 pages) that you should focus on HERE
Go to the summary thread - Yes, your best bet is to get a Vgate device. It is known good, and most others are not. No need to fool around with low-level PID packs and such. Car Scanner supports this directly. You should be able to get it working fairly easily.
I just switched to a second ELM dongle that I have in my other car, and I definitely got more data this time but for whatever reason the Cap didn't read out..
I'm assuming the buffer was full?
Quite likely... Don't waste any more effort.
It was very frustrating when we first went through this process and learned that MOST of the ELM adapters had insufficient buffering.
Insufficient buffering did not just lead to lack of data...
The buffer would wrap-around and the data became jumbled making it even harder to decipher.
Finally got my vGate. I find it hard to believe my battery capacity is this high. I can't get even 40miles in EV mode. Im averaging around 2.25-2.40miles/KWH.
Finally got my vGate. I find it hard to believe my battery capacity is this high. I can't get even 40miles in EV mode. I'm averaging around 2.25-2.40miles/KWH.
Right - Your battery is definitely not that high. The battery capacity measurement on your vehicle has certainly been 'reset'. Over time (it may be a significant amount of time) it will gradually return to reading a true capacity. We do not know details of the algorithm that is used, but it depends on your driving / charging habits as to how quickly it will reflect the true capacity.
If you just drive short distances and don't deplete the battery very much between charges, or if most of your miles are long trips on the highway in HV mode, the capacity measurement will probably take a long time to re-adjust. If you regularly deplete the battery and do frequent full charge cycles, it will re-adjust more quickly.
I suggest that you monitor the capacity on a regular basis (maybe every month, depending on how much you drive) and track what happens over time.
BTW - 40 miles in EV more is not 'bad'. There are 2 big factors that substantially reduce range. First is using heat in the winter (likely not the situation now). Second is speed. It is pretty easy to get the rated range (47 miles) driving around town in the summer at speeds below 55. There is a big difference on the highway - if you are going 65+ you will have a substantial reduction in range. Air conditioning recuces range a little but not nearly as much as heating.
I deplete my battery down to 1 bar just about every day to work then charge to full at work. The majority of my driving is on the highway so I'm sure that doesn't help, I'll keep an eye on the capacity.
I did just buy the car from a Hyundai dealer so maybe they reset the capacity (car has 111k pretty hard to believe I have that much capacity).
Thanks for the info
