KiwiME
I don't have BlueLink as it's not available here but I'm quite certain that leaving the hatch or a door open could easily drain the 12V battery over a few hours. Even worst, as noted many times before an open door disables the 4-hourly charge events as does leaving SoC under 40%.
I check my prior 24-hours voltage log every morning and I'm starting to conclude that the DIN44 capacity is too marginal as it leaves no room for making common mistakes. Several short trips in a row leaves the battery somewhat discharged and it's highly vulnerable to any following additional loads.
I've recently looked at increasing the battery size but there is only one available that is 30mm longer without causing width or height issues. I would have to modify or redesign and construct a new battery tray, not very appealing options.
Regarding Tesla's M3/Y change to a lithium-ion-based 16V system (mentioned above) I had more information provided by a YouTube channel Ingineerix. Both him and John Kelly (Weber Auto) as best as I'm aware are technical experts on Tesla's technologies yet they disagree on how it works. Ingineerix does not accept that the 16V battery is supported continuously by the traction battery and says that the standby system loads have been brought down such that the 16V battery can handle them for a suitable period that does not over-cycle the HV contactors. Only when the park cams are used does the HV help out. Relevant comments are at the top of the list under those links.
Kona below:
Kona below:
