Kiwi, have you found the magnets that stabilize the internal magnet to be worth it? Also, is there a reasonable change interval after the first few changes? I've been changing every 5,000 miles, but would prefer to stretch this out if possible.Yes, you can see the Penrite gives you about a 15*C temp margin over the OEM, perfect for the Australian climate.
It’s cooler here but our road speeds are lower, often the limit is only 80 km/h so it’s perfectly fine because the maximum gear meshing speed dictates the appropriate viscosity.
The black oil seems to be caused by the loose internal magnet and whatever ferrous material it catches, in your case less because it’s only that not caught by the Votex first.
The best we can do is to adopt a suitable change interval in an attempt to keep it somewhat clean.
Did you lease your Kona?I am sticking with 60000 km reduction oil change interval.
Then you're like me with my MINI Cooper SE (not available for lease in the US)--I'm doing nothing above and beyond the warranty requirements to extend the life of its components. I'm driving it hard and enjoying every mile.Nope. I own my Kona.
Probably follow the manual for warranty requirements.Speaking of warranty requirements, does anyone know if we need do certain maintenance items (e.g. coolant replacement) in order to to maintain eligibility for the 100K mile battery/drivetrain warranty in the US? Once I'm out of the 3 year / 36K mile coverage, I don't plan on doing the coolant changes unless they're mandatory for the 100K mile warranty. I asked my local dealer and they didn't really know.
Isn't it interesting how often the dealers don't really know? Especially when they really should know.Speaking of warranty requirements, does anyone know if we need do certain maintenance items (e.g. coolant replacement) in order to to maintain eligibility for the 100K mile battery/drivetrain warranty in the US? Once I'm out of the 3 year / 36K mile coverage, I don't plan on doing the coolant changes unless they're mandatory for the 100K mile warranty. I asked my local dealer and they didn't really know.
My drama with car ended today as they replaced the reduction gear and the ticking noise at low speeds disappeared.
Now it has 50.000km but the ticking noise came around 10.000km
Dead silence in car again
Not sure if that is the last of it. When I had the ticking, they first replaced the reduction drive. Then less than a 1000 kms later, it came back. Next they replaced the motor, and that seemed to fix it. Had the car for another 30K kms, and it never came back before I sold it.My drama with car ended today as they replaced the reduction gear and the ticking noise at low speeds disappeared.
