MrFixit
** I think I've got it ** ??
I looked for codes using the sometimes trusty AP200.
Found a code in the ABS/VSA modue - U0418-68 (ESB/EBB failure).
I cleared this code and no joy.
Then,
Also found the same code (U0418-68) in the Electric Servo Brake System.
I cleared this code, and voila !!
I now have a clean instrument panel. I have every reason to beleive that this was due to the expected result of flushing the fluid while the vehicle was ON. Time will tell if this remains good going forward.
If true, then the service documentation is wrong when stating that the 3-second brake depression will clear the indicator.
I would now recommend against a DIY'er flushing with the brake pedal in the ON mode (unless thay are equipped to clear DTC codes). If you can't clear codes, use the procedure described by @leop in post #58 above.
Then,
