Regarding the potential parasitic drain from the 12v battery with the Vgate iCar Pro BTE 4.0 Auto Sleep feature disabled, using the procedure that
@lincomatic provided in Post #42, I disabled the feature on mine a couple of days ago. Since then, I've accumulated approximately 24 idle hours, equivalent to a full day, and there was an accumulated -0.22v loss during those periods. In comparison, I checked back on 9 idle days prior to plugging in the adapter, and they averaged -0.05v loss overall, almost all of them in the -0.03v to -0.06v range, with a single low of -0.01v and a high of -0.08v. All in all, it seems that the Vgate has probably added an additional drain of about -0.17v loss per day. I know the single 24 hr sample may not be representative, so I'll continue leaving it installed a bit longer to see if it continues with that pattern.
I've had an Antigravity Battery Tracker installed throughout both periods, so that represents an existing parasitic drain included in all of the measurements, but the difference is represented by the Vgate device. I was also surprised to discover today, that I had not disconnected the Car Saver app on my phone after using and exiting the app, and it had remained connected to the Vgate for over 2 hours before I checked my phone battery status, and saw it it still active and connected, so there was some unintentional battery drain on my smartphone as well.
Disabling the Auto Sleep feature is certainly a convenience, but I think that after I collect more data on the drain, I'll pull the Vgate whenever I anticipate long gaps between use. I just received an Autel AP200 today, now awaiting Autel to Register it for the beta, and it will be interesting to see how effective the Auto Sleep feature on that device will be in comparison to the workaround on the Vgate.
