FloridaSun
it could be.. They didn't seem to know the reason why the update was failing..It may be the 12 V battery had insufficient charge to maintain the update procedure (hopefully) and they need to top it up.
No notification on bluelink?
”Inspect” does not imply that it’s visual nor that the battery should removed. Best as we understand the software alone makes an assessment.Between reading the TSB and seeing the recall work is only taking 2-3 hours, it seems clear the Hyundai is NOT physically dropping and inspecting each battery. They are just updating software. Did I read something wrong?
Bluelink (whenever it is working) is great to check car status.. remotely climatize, lock, unlock, locate the car etc. etc..I don't use Bluelink. Have no need for it.
I'd bet that they are looking at cell group voltage variations...”Inspect” does not imply that it’s visual nor that the battery should removed. Best as we understand the software alone makes an assessment.
Thats probably it. I believe they can check for ground faults as well.I'd bet that they are looking at cell group voltage variations...
For sure.. It's unlikely that it includes a physical battery inspection..Thats probably it. I believe they can check for ground faults as well.
Unless there is something specific to look for, a visual inspection won't tell you much. Plus you would need the lift table and special coolant.
Had my appointment today (Friday) for recall /. it took 1.5 hours plus tire rotation. Seems all is well.Just dropped of my car at Hyndai here in Lakeland/FL... They said 1.5 hours but I wouldn't bet on it..
Please report back on charge times.Had my appointment today (Friday) for recall /. it took 1.5 hours plus tire rotation. Seems all is well.
I charge it-slow charging-at 100% twice a week at night while I sleep. Sorry, is this what you meant? Have done this for one and one-half years with no problems.Please report back on charge times.
Sorry again-I can't help you. Don't have any quick charging issues only do slowNo, I meant the quick charging issues people have reported
One of the things we're all trying to figure out if is the update affects charge times. According to the documentation the vehicle is supposed to pause for ten minutes at either 80% or 90% (depending on where it started) to do some sort of testing routine.
There are also a handful of complaints that charging speeds were severely reduced after the update, though those are a bit unclear exactly what the circumstances are. (Edit: this pertains to fast charging only AFAIK, which it seems you don't do so I guess don't worry about it!)
If your setup allows for data logging of any kind, people here would be interested to know if your charging is paused or takes longer than usual.
