Item 7 is programmed for three years in the maintenance minder (MM)... strictly counts down the days until Honda scares you into giving them money. This does not correlate at all to the condition of the brake fluid.
The Clarity I drive has 242 days till the vaunted MM informs the consumer it's time for brake fluid exchange. I take the opportunity to test*** multiple vehicles brake fluid for moisture content (MC) at least once a year which is what I use as one determining factor. Much like
@Landshark, I fully expect 5 years before any exchange in the Clarity is necessary. I let science have a say.
Common sense dictates where you live and driving conditions and habits etc are determining factors of brake fluid longevity. Ludicrous for these manufacturers to place an arbitrary time on fluid exchange as a one size fits all. There are accurate MC processes out there.
Cost? Ridiculous. I just did a friend's brake fluid...the typical car requires 1 qt or less for a full exchange. A name brand fluid was used at the cost of $15.
I appreciate all you folks but it really burns me when I see folks handing over hard earned money to a dirty business like automobile dealerships n manufacturers for what amounts to a wild *** guess of fluid condition.
I think some folks will be surprised how many dealerships test for moisture content then only replace the fluid in the reservoir and call it good.
Since I have assisted with several Clarity's on maintenance...I will update this thread if/when I do a brake fluid exchange.
* Since I test multiple vehicles at once I test the first with both a strip and electronic tester as a gauge of accuracy for the meter. Confidence in the numbers is key.
